Lower steering shaft support bearing.
Guys.The rubber bushing as pic, that locates on the lower steering shaft.Can anyone
advise as to whether the bearing locates directly into the rubber bush, or whether there is a metal sleeve it locates into first.
the bearing is long gone, but I have a metal sleeve without a home.
Cannot find a definitive answer.thanks.
Old 09-05-2020, 10:02 PM
proporsche's Avatar
the rubber bushing has the needle-bearing inside itself-it is one unit...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-06-2020, 03:56 AM
Harpo's Avatar
914 rubber has a replacement
Old 09-06-2020, 05:42 AM
Ivan
Hi thanks for that.So the bearing does not sit in a sleeve,It merely sits in the rubber bush?
Old 09-06-2020, 05:44 AM
Has a replacement what sorry?
Harpo's Avatar
Bearing + metal sleeve + rubber bushing
https://914rubber.com/steering-bearing-1
Old 09-06-2020, 06:36 AM
thanks for that! I thought it had the sleeve.Doesnt show anywhere on Porsche parts
Old 09-06-2020, 06:54 AM
It's a 914 ...
stownsen914's Avatar
Looks like the 914rubber version is two piece. I recall buying a Porsche replacement one years ago and it was one piece with integral needle bearing.
Old 09-06-2020, 09:58 AM
burgermeister's Avatar
The bearing inside the donut is an 1117 I think, available from any bearing supplier. It's a needle bearing, uses the steering shaft as the inner race. Same bearing is used to support the pinion shaft inside the rack. You can just push a new one into the rubber donut. Or, better yet, make a teflon bushing... the area seems to be subject to corrosion, and the needle bearings don't seem to hold up all that well once the shaft gets pitted / worn.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-06-2020, 07:20 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yes there’s a metal sleeve to contain the needle bearing. You’ll also want to consider installing some radial seals (similar to crankshaft oil seals) in the sleeve to keep the dirt out. Got mine from metricseals.com
You also can replace the rubber mount/vibration isolator with a soft yellow poly unit from Powerflex. I got mine from Pelican
Kevin L
'86 Carrera "Larry"
Old 09-07-2020, 06:30 AM
Great input thanks guys.Have ordered the one from 914 rubber.com, about an hour before burgermeister posted bearing number!
Old 09-07-2020, 10:09 PM
