				1971 911T turn signals
			Turn signals don't work (either left or right) but 4-way flasher works fine.  Could it still be the flasher relay?  Or do I need to take the steering wheel assembly off to check the contacts.  Fuses are all ok. Thanks
			 ROW '78 911 Targa
			Check the 6 pin plug for the turn signals wiring under the dash is tight.
	Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.  |
			When this happened on my 1978SC it was the fuse (#11 I think); the fuse was intact but the ends were corroded.
	1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993)  |
			 Under the radar
BTDT.  The ends will burn on the fuses.  Use a volt meter to check for continuity.
	Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage  |
			It's also worth noting that on my 1978SC the hazard switch is powered through fuse #17 which is always hot which means the hazard lights will work with the ignition off. Fuse #11 is hot only when ignition is on. And on my car the brake lights are also fused through #11 and they weren't working either which was a big clue that the fuse was corroded. Strangely both Haynes and Bentley say brake lights fused through #15, but I go by what it says on the fuse cover. Check your fuse cover to see what the fuses do.
				problem solved
			Thanks for the help.  When it was pointed out that the flasher works without the ignition being on, that really pointed me back to the fuses.  I had checked them all (easy to do as they are the old open type), but now I took the fuse out for the blinker.  While the fuse element was intact, the end had broken off. See picture.  Replaced it and now all good.
	![]() Denham  |
			Glad you found the problem. I had the same problem but it was only when I noticed that the brake lights weren't  working either that I found the fuse to be corroded. I had a lot of wiring from past alarms etc under the dash and took the opportunity to tidy all that up to the other side of the bulkhead. Quite a big job but so much better and was able to throw away various obsolete components that previously I didn't dare touch in case the alarm and central locking stopped working. It was only once I had cleared all the old wiring that I could get at the hazard switch. The indicators failed while I was out in the car and had to drive back giving hand signals and would have been even more concerned had I realised that the brake lights weren't working either!
