Fire Extinguisher placement
Where’s the best place to mount a fire extinguisher in my 1970 911
Thanks Brian
Old 09-07-2020, 12:38 PM
Driver
Noah930's Avatar
I like the passenger seat rails in the front seat. It's something I want to be able to reach even if belted in (in the event of a bad crash, where I'm stuck).
1990 Black 964 C2 Targa
Old 09-07-2020, 12:43 PM
proporsche's Avatar
i have mine in the engine compartment...installed it is called Viper made and patented in Czech Republic by mr.Cervinka..
here is how it looks.
https://www.hasicitechnika.com/en/novinka/upozorneni-car-viper
1985 911 with original 502 191 miles...808 198 km
Old 09-07-2020, 01:32 PM
I have 4 Element fire extinguishers in the glove box of the '70. Also usually carry 2 HalGuard extinguishers on the rear floor padded. You can't have too many. Ask me how I know.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 09-07-2020, 01:42 PM
Brian : as in alot of options - it all depends.
- do you track your 70 911?
- do you have harness bar - roll cage?
- is the fire ext a be-prepared option?
In my situation - I have a 1980 911SC with a harness bar [got at a sweet$$] so I mounted my halon FE at the harness bar... good mounting point - accessible by driver/pax..
on my 991 I opted for a floor mount -
I don't track either of my 911s so I'm not expecting fire > but its always good to be prepared
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 09-07-2020, 02:06 PM
I mounted an element extinguisher under the passenger seat on the tunnel side so easy to reach from either seat or door. Sticks out a bit so it’s visible.
Old 09-07-2020, 08:41 PM
HarryD's Avatar
Mine is under the driver seat.
Originally Posted by HarryD View Post
Discussed many times here. Do a search. Find threads like this:
Fire extinguisher, where would you place it?
And this:
My low-budget Fire Ext Bracket
And this:
Fire Extinguisher Location
And this:
fire extinguisher in your P-car - any pix?
And my solution under the drivers seat:
The car is a '73 but the seats are from a '77. I put an aluminum "el" between the the two front bolts that hold the slider to the seat adapter plate and attached the bottle.
And this:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-09-2020, 07:28 PM
