911 Foam Engine Compartment Sound Pad..DIY?
I like projects! Thoughts on making my own 911 coupe Foam Engine Compartment Sound Pad? Looks easy...have my old one as a template.
Old 10-05-2024, 01:13 PM
E Sully's Avatar
Looks good. What did you use?
Ed
1973.5 T
Old 10-05-2024, 01:15 PM
If you have accurate measurements, a laser cutter, and the right material, it would be a piece of cake. The right material seems to be the hard part.
Old 10-05-2024, 03:44 PM
HarryD's Avatar
I used some of this and glued it in with contact cement. Eyeballed it in.
https://www.amazon.com/gp/product/B09BR3PN4V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-05-2024, 06:04 PM
This seems a strange one when you can buy a proper one for the car for so little money
Old 10-05-2024, 07:34 PM
E Sully. I didnt make that. Its the original part...like to copy that
HarryD. the amazon link didnt come up...what did you use?
Ian...my birthday is in Sept!...like I said ... I enjoy a project.
Old 10-07-2024, 11:57 AM
HarryD's Avatar
My search terms were: Closed Cell Sponge Foam. I ordered the 1/2" thick, 17" wide and 80" long material from Artlife. They no longer have the one I ordered.
They have this: https://www.amazon.com/Artilife-Neoprene-Perfect-Cosplay-Padding/dp/B08FX3V8Z7/ref=dp_prsubs_sccl_2/134-3904841-5801715?pd_rd_w=KOAda&content-id=amzn1.sym.b3f15950-3c9d-4907-ad05-73533fd419e9&pf_rd_p=b3f15950-3c9d-4907-ad05-73533fd419e9&pf_rd_r=YD3SC7Y635V4AWPQR1CH&pd_rd_wg=iONGj&pd_rd_r=a6f91304-466d-429e-a54b-13e2da06c355&pd_rd_i=B08FX3V8Z7&psc=1
Harry
2020 MB E350 4Matic
Old 10-07-2024, 12:29 PM
how long?
wow, why 80” long? that just the size sold?.. obviously didn’t need 80”
I found 1/2 X 39 X 78 online at Homedepot site
Old 10-07-2024, 07:38 PM
HarryD's Avatar
It was what they offered and I use the foam for other things as they pop up.
Harry
2020 MB E350 4Matic
Old 10-07-2024, 08:31 PM
If I had it to do over again I would get a Lizard Skin kit of both their sound deadener and their ceramic under coating. My project would be coat the whole firewall with both first. then I would buy the best quality foam pad I found and just glue that in. Probably the same time spent, a fun project still, and the best outcome. Just my 2 cents, and you got it for free so......take it for what it's worth.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 10-08-2024, 09:05 AM
i found that Porsche dealer sells it fairly cheap. a lot less than most others. $97
Old 10-08-2024, 02:16 PM
Tags
engine compartment , foam , sound pad
