DME Relay failure - Prevention and Repair
I had the mysterious and intermittent non-start problem in my 3.2 a few months ago traced to the infamous DME relay. Replacing it with a new one for $45 from the dealer, I kept the old one as a spare in the glovebox until I decided to open it this weekend to analyze what causes its intermittent failure. Figuring it could only be one of two causes, either a weaking relay coil, or a break in the circuitry, I took a magnifying glass to examine the relay. First off there are two relays enclosed soldered onto a single fiberglass circuit board surrounded by a few simple components such as a resistor and diode. One is the main relay and the second is the fuel pump relay. Its function should the car be in an accident, is to shut off the fuel pump relay and thereby prevent the fuel pump from dumping raw fuel. A close look at the relays showed them in good health with no broken coil wires, overheating, or worn out contacts. However a close look at the underside of the circuit board revealed all the causes of mysterious failures. Close examination of the solder joints on the relay farthest from the plug terminals, the fuel pump relay, revealed that almost every single one of the five or so joints had a hairline crack in the solder encircling each entire joint. With a digital multimeter, I actually measured no contact at two of the joints between the relay and the circuit board trace. Those two points though were relay supports and not part of the circuitry. The other three points which were also cracked all the way around, however at the time, had measured continuity. But because they were cracked, they would cause intermittent start or no start conditions. I think these joint failures are caused by two conditions
1) poor quality soldering or solder at the manufacturer, and 2) the way the relays are mounted in the car cantilever them horizontally off the circuit board placing lots of stress on the low quality solder joints, especially with cars that have stiffer suspensions or stronger vibrations. Over time, each joint failure will place additional stress on the remaining joint, accelerating their failure So my repair was simple. Pull out the soldering iron, and reheat all solder joints - THOROUGHLY - making sure the heavy copper relay plates are sufficiently heated to prevent a cold solder joint, and preventing any movement until the solder has naturally cooled. I also added more solder to strengthen the joint. Good and better than new, and back into the glovebox it went. Even if your DME relay hasn't failed yet, it could be on it's way and you can prevent it. My suggestion for those that know how to use a soldering iron is to resolder and reinforce all your solder joints in your relay to avoid being stuck at the worst time. You may be surprised at what you find and will save yourself a lot of $$ and headaches in the future. And if you don't know how to use a soldering iron, well I guess carry a spare. Last edited by Steve W; 04-20-2003 at 11:37 PM.. |
Irrationally exuberant
Excellent info Steve!
-Chris |
Certified Pre-Owned
Thanks for the info -BG
'84 Carrera Coupe |
Senior Member
Where exactly is the DME located and did this go into all model year cars? It may be time to think about remounting.
Thanks for a great thread, John
'78 Targa in Minerva Blue |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
84-89 cars with Motronic systems.
Location. Right under your "arse" ![]()
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
I've put soft rubber washers under the four mounting studs that hold the DME in-place. Looks like a soft rubber block, or such, under the cantilevered relay might be a good thing, too !...
--Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Another question- does the intermittent starting problem related to the dme interfere with the starter itself- or will the engine not run. I have had a very intermittent problem with the starter not turning over- we have changed the starter, checked the ignition switch, etc. It now only does it about 3 times a year, and self corrects itself immediately- which is even making it harder to find.
thanks Gary |
With a bad relay it'll crank until the battery dies, just won't start.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
Great write up Steve tnx for that, and Wil the rubbers under the dme and relais is a great idea as well
87 Carrera Backdate |
Thanks guys. Had I known about this problem, I would have just resoldered the joints and saved myself $45 and a lot of headaches with all the times I was stranded on the road. I think the most important thing for all 3.2 owners to do with respect to the relay is to just resolder all the joints to prevent these sort of problems. Removing the existing solder and replacing it with some decent quality solder may also help, but adding a little more, and heating it right is probably most important. The relays are a relatively heavy mechanism of copper plates and wire coils, and they place a lot of stress on those solder joints mounted horizontally like that. Wil's suggestion is also a good one, can't be too careful.
UFLYICU
Careful guys
It should be understood that "more" solder is almost NEVER better. The preferred method would be to remove the old solder by suction or wicking, and re-solder the joint with new solder. Adding solder to the existing may cause shorts across foil runs, or other unwanted currents.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Rebuilt DME relays anyone? Don't throw it away have it rebuilt for a fraction of the cost of new.
Steve, will you do the same analysis for a fuel pump relay?
Stopped racing and became a drummer |
Well done Steve, and thanks for the heads up.
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
Large Registered Member
DME Relay?
While I have your ears guys...
Might my problem be related to the infamous DME Relay? I've got an '85 3.2 with an intermittent rough running problem.... Occasional rough idle, loss of power or bog around 3-4,000 RPM under light to medium throttle, and occasionally under full throttle... Any thoughts? Patrick ![]()
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
timeless beauty
http://forums.pelicanparts.com/showthread.php?threadid=185563&highlight=dme+relay
If you can get to this post we have some pic's on relay and testing. |
Partial running problems?....would think it's one of the 2-3 sensors that help operate the engine( speed and reference sensors....maybe even O2 sensor if you're still running closed loop as stock).
Wil
My friend who is a german car tech has been repairing solder joints in MBZ fuel and AC relays for years. I have one in my MBZ now, BTW. He sees the same thing, hairline cracks, thinks it might be from the heat, but who knows.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
