Help diagnosing an engine noise
I've edited this post with a better video. You can hear the sound pretty distinctly when I place the camera near the transmission crossmember at the end of the following video:
https://youtu.be/iqjwFWcr0Vs
I think I'm hearing a new sound. The best example of the sound is in the video at 0.50 - 0.55 seconds.
https://www.youtube.com/watch?v=dRQr7JRD-xw
I apologize for the terrible camera work. :-)
For context, 3.0 engine with 40IDA Weber carbs. The coughing/sneezing out the carbs and exhaust pops aren't new. The engine runs great with lots of power at RPM and was setup for track use. Idle leaves something to be desired, but it's a DE car and I have not dug into tuning. It loves RPM.
I've used a long pry bar to listen to the intake valve covers, exhaust valve covers, and timing chain covers. Nothing stands out to me.
The irregular sound in the video concerns me. Any ideas? Thanks in advance.
Last edited by Locker537; 10-05-2020 at 05:49 AM.. Reason: Including a better video
Old 09-13-2020, 12:03 PM
Valve train. Rockers to loose.
Old 09-13-2020, 12:21 PM
I was planning to adjust them soon, so that would be good if that's it.
Old 09-13-2020, 12:30 PM
proporsche's Avatar
ok 1st you should have you valves adjusted...2nd the clunk on 0,50 is possibly your flywheel is loose
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-13-2020, 12:37 PM
Ivan
That thought crossed my mind based on reading other threads. Not from personal experience.
Is there a way to check the flywheel? I assume I'd be dropping the engine and transaxle.
I'll start with the valve adjustment.
Old 09-13-2020, 02:49 PM
Update to this thread.
I've adjusted the valves and the noise is still present. I was able to capture it better in the following video. The noise is most pronounced from the transmission crossmember area.
Any ideas?
Old 10-05-2020, 05:50 AM
sounds like it's in the valve train to me. Collapsed tensioner?
Old 10-05-2020, 06:27 AM
I can certainly double check the valves. I know it will be much easier the second time around!
Should I pull the tensioner covers and visually inspect?
I can really only discern the noise from under the car. It's most pronounced near the crossmember. I used a scope to pinpoint it and failed to do so.
Old 10-05-2020, 06:41 AM
Sounds like chain rattle but it's hard to tell from listening to a audio clip. Wait for some members to respond. Did the noise change after the valve adjustment?
Old 10-05-2020, 06:52 AM
Not in any noticeable way.
If I wasn't able to capture it on video, I'd say I was imagining it.
Old 10-05-2020, 07:25 AM
proporsche's Avatar
the valve adjustment seems fine..but we are talking about the knock right? have you driven the car since?
Ivan
Old 10-05-2020, 10:27 AM
Yes, the "knocking" sound that you can hear pretty clearly starting at the 25 second mark in the video until the end.
Yes, I drove it and it runs strong. Nothing appears wrong other than the noise.
Old 10-05-2020, 02:05 PM
Wait for John Walkers advise.
Old 10-05-2020, 02:54 PM
proporsche's Avatar
does it change when step on the clutch pedal?--i sounds like from the trans. main shaft
Ivan
Old 10-05-2020, 10:23 PM
Ivan
I could not discern a difference while listening from inside the car, but will need to get a helper to step on the pedal while I am under the car. Good idea. Thank you!
Old 10-06-2020, 04:55 AM
After adjusting the valves to eliminate that possibility, I replaced the spark plugs. I then went for a ~10 miles drive, a couple wide open throttle blasts, then pulled into the garage and let the car idle while hunting for the engine noise in the videos above.
My understanding is inspecting plugs after long idle won't indicate much, but I pulled the plugs to check them and was surprised by how sooty #4 and #5 are compared to the others.
Any thoughts? Could it be related to the engine sound?
Old 10-06-2020, 07:09 AM
When adjusting the valves, did you check for broken head studs? Especially around cylinders #4 and #5?
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 10-06-2020, 07:14 AM
No, but I will add it to the list. That would be very surprising given the history of the engine. It was rebuilt in 2006. I suppose that's longer ago than I realize typing it out...
Old 10-06-2020, 07:31 AM
Thinking out loud...
Could it be the throttle linkage? I noticed there is a good amount of play in the part that pivots near the transaxle. I kinda doubt it...
Old 10-06-2020, 02:25 PM
Ivan,
The noise does go away when I depress the clutch. I confirmed this over the weekend.
Old 10-19-2020, 07:25 AM
