Clutch cable clevis removal
Do you press the clutch pedal in to get to the clevis pin?
Replacing the pedal box, anything else I should be aware of?
Old 09-14-2020, 03:37 PM
Dosconnect the cable at the trans first.
206 637 4071
Old 09-14-2020, 03:54 PM
I used some penetrating oil and an open end wrench and was able to remove mine.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 09-14-2020, 03:55 PM
This car is like pulling a string on a sweater.....
Old 09-14-2020, 04:39 PM
ROW '78 911 Targa
timmy2's Avatar
😂 now that is funny, I feel for ya, but a great sense of humor helps.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-14-2020, 06:05 PM
911tracker85's Avatar
I will have to remember this quote. I understand.... dont ask me how I know...
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-15-2020, 07:14 AM
I am looking at Lotus Elise's as we speak... I might not be German car material lol.
Old 09-15-2020, 11:37 AM
How are you guys getting to the clevis retaining clip, its mostly buried
Old 09-15-2020, 04:31 PM
I don't remember it being that challenging to access. But I was way up in the footwell!
Old 09-15-2020, 05:16 PM
Did you disconnect the cable at the rear yet? Then the pedal goes down and you can get at the clip.
206 637 4071
Old 09-15-2020, 08:05 PM
Got it off, from the pass side top hole... then pulled it out from the drivers well
Old 09-16-2020, 07:15 AM
Listen the John he's trying to help you. It's going to be a pain to reinstall unless YOU DISCONNECT THE CABLE FROM THE TRANS.
Old 09-16-2020, 07:20 AM
With all the brake fluid under the pedal box what should I do to prep that area?
Also, do you grease the little ball joints?
Old 09-16-2020, 03:23 PM
Any ideas on if I need to treat that area that had break fluid on it?
Old 09-18-2020, 03:34 PM
IF I am removing the clutch cable at the trans, will I then need to get a feeler gauge and readjust the clutch once I put it back together?
Do I loosen the forward nut on the clutch cable mount at the trans? Will that release tension to the front of the car?
Old 09-19-2020, 04:53 PM
pete3799's Avatar
Yes you will need to readjust the clutch.
Hook a bungee cord on the clutch pedal to hold it in the up position then loosen the nut on the cable and remove it.
Pete
79 911SC RoW
Old 09-19-2020, 05:03 PM
The clutch pedal isn't connected to the clutch cable.... i'm putting in the new pedal box now, everything is connected except the clutch cable at the pedal box.
Like John suggested, I will need some slack to connect it. I just wasn't sure where I get the slack from. The two nuts inline at the transmission. For adjusting you loosen the forward nut, does that release all the tension allowing me to pull the cable forward enough to get the clevis pin into the cable?
Old 09-19-2020, 05:13 PM
Banned
I just put it back on. I remember it being a ***** to get my hands on it but I was about to maneuver it on. The bungee cord to hold up the clutch pedal is a good idea, don't want it snapping down.
Old 09-19-2020, 07:35 PM
I can't get the clutch cable forward enough to get it onto the clutch pedal arm. I know I have to disconnect the clutch cable from the trans, just not sure EXACTLY how to do this.
Old 09-20-2020, 06:17 AM
I am my 911's PO
'78 SC's Avatar
Did you replace the clevis? There is a spec on how far to screw it on (so the adjusting nuts at the transmission are in the right place). Bentley says 17-22mm of threaded cable end screwed into the clevis.
Old 09-20-2020, 07:31 AM
