Which headlight is this?
Can you tell me which headlight this is?
And what is needed to make the other side exactly the same?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-15-2020, 12:52 PM
Looks like a standard Bosch h4 --https://www.pelicanparts.com/More_Info/91163111300.htm?pn=911-631-113-00-OEM&SVSVSI=0811&DID=12453
Old 10-15-2020, 01:02 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
To make them the same, remove and toss that crap H4 and get a manly set of H1s in that longhood.
https://www.autoforeignservices.com/
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 10-15-2020, 05:03 PM
Mark Salvetti's Avatar
Perfect timing (no affiliation): Bosch H1 Headlight Pair
Although those repros linked to above look pretty sweet (and cheaper).
Mark
1979 911SC Targa
Old 10-15-2020, 07:16 PM
Bill Douglas's Avatar
Awesome paint work!
Old 10-15-2020, 09:28 PM
Headlight fall out?
Old 10-15-2020, 10:29 PM
Flojo's Avatar
Originally Posted by 70SATMan
, remove and toss that crap H4 and get a manly set of H1s in that longhood.[/url]
what's wrong with H4?
just swap the bulb for some nice LEDs
I did.
BOOM!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-16-2020, 03:45 AM
Originally Posted by nathanbs View Post
Headlight fall out?
Yup. Somewhere on the 101 is a nice headlight for a 911 being run over by an 18 wheeler.
Old 10-16-2020, 07:27 AM
Rescuer of old cars
Arne2's Avatar
Looks like the car has the later thick rubber seal, which makes it difficult to get the headlight properly mounted. Make sure you get a pair of the correct early-style thin seals and replace the other one too.
Nothing really wrong with H4s. I had them in my '84. But I have the above mentioned H1 repros in my '72. I like that the high and low beams can be adjusted separately, and also that H4 for Porsche were not released until 3/72, so H1s are "more correct" for earlier cars.
The repro H1s from Auto Foreign are awesome, look like jewelry!
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-16-2020, 08:38 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
I did.
BOOM!
Just joking! H1s are an iconic look and H4s look bland to me... Sure, they work OK but, as you pointed out, you added LEDs so,,,,,,,
Old 10-16-2020, 08:55 AM
