heat cycle new tires?
The Bad news: Saturday night my front right tire blew out while I was doing 70 on the freeway. I bit freaky, but she stayed on the road with a lurch which was controllable and I was able to pull over to the shoulder untill AAA arrived. It was my first experience watching a tow truck driver struggle to get her up on the flatbed without ripping the oil lines off the front.
The Good News: I picked up a set of Yoko AVS Intermediates during the TireRack blowout sale in the Fall, so this is the perfect time to mount em up.
The Question: Do these need to be heat cycled on the first trip out? If so, do I have to store then horizontally for the following 24 hrs?
I know that new tires will always be a bit slippery in the begining, and I know that race tires are supposed to be heat cycled as soon as they are put on. The archives aren't definitive on the issue. BTW, the car is a weekend drive (some of it spirited).
Adam
Old 04-21-2003, 07:34 PM
Cool
this topic was recently covered.. personally I figured it can't hurt to heat cycle new sneakers............................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-21-2003, 07:37 PM
makaio's Avatar
IMHO I don't think it is needed on street tires.
Old 04-21-2003, 07:41 PM
Cool
yeah Matt.. your probably right.. I haven't read any hard info on street tires..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-21-2003, 07:48 PM
Administrator
Jack Olsen's Avatar
AVS intermediates aren't race tires. They're not going to be particularly sensitive to heat cycles. Your first couple of times out will be a little less sure-footed than later. The tires will be better once they're scrubbed in, and the releasing agent had cooked out.
Cool
yep.. sounds logical..
maybe tire rack could supply hard info on this.. I need new tires soon.. I should ask them.. they'll probably ask me to read the marketing stuff and hope I'm satisfied w/that..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-21-2003, 07:55 PM
Thanks guys, it'll be a little easy going at first, but at least I won't have to throw her up on stands after the first trip.
Old 04-21-2003, 07:57 PM
