engine deck lid/hood
Hello Pelicans,
![]() I am having an issue with the hood/deck lid of my '88 Cab. It won't stay closed. I've tried several times in adjusting the latch and afterwards it will shut nice and seem locked. I will pull, shake, rattle and pull to try and simulate driving. If it stays closed, I will go for a drive...at which point it will pop open every time. Am I on the right track, but missing something in adjusting the locking mechanism? Or is there something wrong/broken with the latch? Thank you |
New-ish 911SC Targa Owner
Unscrew the spring loaded latch (I think it's just a straight screwdriver head on the decklid itself so that it is longer. That did the trick for mine
It is a good idea to remove the grille BEFORE you attempt adjustment. When adjusting bear in mind that the cable must be pre-tensioned. First make sure that the handle is fully screwed onto the cable at the door end. At the lock end loosen the cable clamp screw; the lock will then be open; it opens automatically if the cable breaks. Move the lever with the clamp screw to a point where you can see most of the "blade" and tighten the clamp screw. Test. If it fails to open you can reach in through the grille opening and release the lock lever by hand.
It is important to realize that the lock has two open positions: one when the cables has no tension and two when you pull on the handle. This clever design means that if the cable breaks the lock opens, otherwise as you have found there is a problem. The front hood lock was the same on the early models but has been changed. Presumably it was thought not to be such a good idea to have the hood unlock at speed.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Thank you. I wasn't aware of the cable tension/broke cable feature. This is good to know. I will definitely remove the grill and start from scratch. Insure the pull handle/cable end is good then go from there. great insight,
Hose the latch mech down with some spray lube to make sure everything is moving freely. If the latch is sticking at all, you'll never get it to adjust and hold correctly.
As mentioned, the latch is designed to release the hood pin under two conditions:
1. By pulling on the hood release cable. 2. When the cable breaks and/or if cable tension is lost. That indicates the latch provides an open-close-open format. The proper adjustment is when the latch blade/cable adjustment creates the narrowest hood pin opening. With the cable stop screw loose, manually move the spring-loaded latch back and forth and observe when the hood pin opening is at its narrowest opening. That’s the optimum position to lock the cable stop lock screw. Sherwood |
thanks to all. |
Well...
I've adjusted the latch to the "sweet" spot and it still pops open while driving. While in the garage, I will attempt to pull, shake, push down and rock side to side trying to pull or "pop" it open, but it doesn't. It stay locked and secured. And the minute I start driving...POP! ![]() Am I missing another adjustment that may be needed? it's like the latch is attached to my clutch cable or something...
Try winding the rubber snubbers out 1/4 turn or so
Sherwood |
Would someone be willing to take a picture of what screw/latch pin
The position of the stop along the wire determines how far the latch moves to release the vertical hood pin. An archived Pelican thread has a photo of the latch: Need help: tips/tricks for front hood latch adjustment (73) There's more latch adjustment links here: https://www.google.com/search?q=porsche+911+hood+or+engine+latch+adjustme nt&source=lmns&bih=1258&biw=1811&hl=en&sa=X&ved=2ahUKEwiB26293ZLsAhUiI30KHRVND1UQ_AUoAHoECAEQA A Hope this helps Sherwood |
What problem are you having with the rear lid?
