-   -   High Idle Issue (have searched) (http://forums.pelicanparts.com/porsche-911-technical-forum/1074554-high-idle-issue-have-searched.html)
tuddy 10-01-2020 07:43 AM
Hey All, I have done my research but need some opinions.
1980 SC 3.0/915/402k
- idles at 1800 cold or hot
- does not decelerate (engine brake) while in gear
- can get it to sit at idle speeds by knocking it down with the clutch OR adjusting idle screw. raises once throttle is blipped.
From what I have read, this is the AAR. I cleaned it but nothing changed so I took it apart and manually closed the flap and reinstalled without plugging it in. No change.
***Also my Decel Valve is disconnected (cant find the line) BUT the AAV also has a vac port that is connected (i havent seen setup where they both have vac ports.***
Options:
- decel valve behind CIS? it doesnt decel, could this be common sense?
- AAV?
- Vac leak- What is the normal vac for these motors? I can hook up a boost gauge to a vac line to see what it is at in hg
- timing? it runs great otherwise, no pops or bucks so i doubt it
- vac advance or dist springs?
Mixed76 10-01-2020 08:11 AM
Make sure the accelerator pedal is returning properly/ throttle is closing.
Sent from my Nokia 7.1 using Tapatalk
tuddy 10-01-2020 09:18 AM
My car has vac ports on both the AAV and the Decel Valve. Is that normal? Currently the DV is not hooked up and I cant find the line for it but the AAV is hooked up.
Pic from research:
http://forums.pelicanparts.com/uploa...1601569036.jpg
nomore 10-01-2020 10:43 AM
Agree w/mixed 76, make sure throttle is not binding. Pedal, throttle rods, bushings and butterfly need to be checked.
AndrewCologne 10-01-2020 02:43 PM
The pic showes a mixed up installation of the AAV and Deaccel.Valve.
The AAV should be above the Deaccel.Valve.
