Hardware for installing Recaros in 74-up 911s (informational)
I thought I'd share this information for the benefit of future searchers. I put a pair of old Recaros (LXA or KR, not sure which) in my car recently. I'm not sure exactly how old my seats are (I'm thinking 80s) but the underside of the seat pan is stepped, such that factory rails won't bolt directly to it. Perhaps spacers would work with them as well, but I just went ahead and got a pair of Recaro double-locking sliders. These required spacers due to the step in the pan.
I used this hardware: McMaster-Carr p/n 92235A217 (Flanged Socket Head Screw, M6 x 1 mm Thread, 30 mm Length, Pack of 10) - to mount the rails to the seat pan. (8 needed.) McMaster-Carr p/n 98040A105 (Black-Oxide Steel Oversized Washer for M8 Screw Size, 8.4 mm ID, 22 mm OD, Pack of 5) - to space the rails out from the seat pan, and also to space the rails off the floor mount a bit. (24 to 32 needed.) Porsche p/n 900-186-018-02-OEM - to attach the rails to the floor of the car. (8 needed.) If you have certain other years of Recaros, you may not need or won't need the spacers between the rails and the seat. I needed the spacers between the rails and floor because, using the existing holes drilled in the Recaro slider base that match the hole spacing in the floor, a weld at the rear of the floor bracket kept the rail from sitting flush. If I'd used the other hole in the rail base and drilled a new on at the correct spacing, I wouldn't have needed this spacer and the rail would have sit flush on the floor bracket. I didn't have to use new hardware here, I just wanted to. Despite the spacers, the seat leaves you sitting at least a couple of inches lower than stock pre-85 comfort seats, which I happen to like. If you wanted to sit higher you might be better off with a box-section spacer. I was OK with the heavy washers based on the height needed. I had hex-head bolts in the original rails, but you have to use OE-style recessed head bolts (with a ball-end Allen wrench) on the Recaros, as there's no tool access for a 10mm socket and ratchet. I'll attach photos later.
'80 SC Targa Avondale, Chicago, IL Last edited by Otter74; 10-04-2020 at 06:45 PM.. |
I used Sparco seat spacers. Much easier than stacking washers.
https://www.ogracing.com/products/sparco-seat-spacer-kit?gclid=Cj0KCQjw5eX7BRDQARIsAMhYLP8mVIzpn6w4N5GT c36DsLbVtrNycHw3BgvtbEaKf8LUA4Xuix47QaEaAkOPEALw_w cB |
Registered Minimalist
Edit: I think I understand your mount setup, I'm just interested as to how they are lower than the stock comfort seats. when I tried my Recaro Pole Positions, they sat higher using the double slider recaro rails on the stock tub rails.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 10-05-2020 at 05:30 AM.. |
I saw those but it would have taken me a while to get a set in or have someone machine a set locally (I can’t do it myself), whereas I could get thick washers from McMaster-Carr the same day. At only three per, they weren’t hard to deal with.
'80 SC Targa Avondale, Chicago, IL |
Sorry for not being clear enough. No, I mounted them to the factory seat mounting locations. That’s what I meant by ‘floor pan’ (as opposed to seat pan)
I have a pair of Pole Position ABYs arriving today and I want to mount them as low as possible. I'm not against fixing the driver's seat in place, but would prefer to have it on a slider.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Anyway, they are intended for my 77 project, and since I'm down to a bare tub, I'm modifying the rails to accommodate my huge frame (6'6" 230lbs) I'm moving them back roughly 5" inches and nearly down to the floor. Well I'm welding in new mounts and cutting the others out. Yes yes the fuel line. Did you get steel or aluminum side mount plates?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I'm 6 feet tall, biased towards torso length, 155lb so pretty thin. I can see the gauges a little bit better now and the cushion angle for my legs is perfect. I spent ~2500 miles in the car a few weeks ago, including a couple of 17-hour days, and they are all-day comfortable.
I'm bummed to hear that you lose headroom with the ABEs, but not surprised given what I've read. I am surprised there isn't a well known / documented procedure or parts list for installing Pole Positions. Hence, my entreaty earlier this year... Recaro Pole Position '87 Carrera install best practices? Southbound Trimmers mounts? I've inquired into other mounts (Southbound Trimmers, Brey Krause, etc.), but haven't gotten anything definitive. Edit: Seats are IN! Aluminum side mounts. Final pic is last night's rest rig! ![]() ![]() ![]()
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 10-06-2020 at 06:26 AM.. Reason: Added pics |
I mounted up the passenger side Pole Position Classic and, as expected... it's AWESOME!
Looks killer, feels GREAT and I gained some headroom, which is a *BIG* plus... ![]() More info here... Recaro Pole Position '87 Carrera install best practices? Southbound Trimmers mounts?
Thread Tools | |
Rate This Thread | |
