the resistor is limiting the current.
I only know what I need to know with electricity.
But I think capacitors are amazing. |
although looking at the ciricuit, and its been a loooooong time since I have thought about basic ELEC, the LED will light with the SW in both positions.
although momentarily off until the CAP charges up. with no resistor in series with the CAP and no known value, it would probably charge almost instantly. in electronics wire is normally not taken into account. It is possible it "could" be considered in very low voltage circuits. the LED IS a load. it does have a voltage drop across it. diodes are normally about .7v, I think an LED may be higher. |
The only thing in the entire circuit is the capacitor and the LED. There is no separate resistor !! |
If you follow the lines, you can see the traces apply either forward bias (positive voltage) to the motor or reverse bias (negative voltage). The switch just changes the polarity. DC motors are neat because they can run forward or in reverse just by this simple change. They are really not much more complicated than that for a basic intro. These cars were developed in a pretty basic age as far as car electronics go. I think the most complicated issue is knowing where all of the wires go and which circuits are tied to which. The actual functioning of the circuits is pretty straight forward. |
All of a sudden I heard a pop and he jumped over me like an Olympic hurdler and ran out of the room like he was on fire. I found him sitting in the hall and his lips were blue. And that’s why to this day I think it’s helpful to have an EE friend around to teach the rest of us about electricity. :D |
First reply that is actually on topic. The battery wire goes through 2 fuses, #17 & #18 Why is one yellow and one red? Wire then goes into the J relay. Ignition switch closed, power flows through 85/86, which then closes 30/87, allowing current to flow to window switch E39/E41. Finally reaching the window motor at V15. http://forums.pelicanparts.com/uploa...1298316365.jpg http://forums.pelicanparts.com/uploa...1298316347.jpg |
