Unknown part loose in engine bay
Tried on Renlist now to try here with all you gurus out there. Found a part floating around in engine bay while attempting fuel line exchange. Hopefully someone knows as last forum advice showed blitzed gearbox housing and image of similar part :rolleyes:http://forums.pelicanparts.com/uploa...1601944708.jpg
http://forums.pelicanparts.com/uploa...1601944823.jpg |
Is the part threaded or is the interior smooth?
What year car? |
It almost looks like the spacer that goes under the throttle linkage in the 3.0 and 2.7 engines. I think those measurements are 37mm L, 13mm OD, 8mm ID.
Looks like the spacer for rear shock
Rear shock spacer in engine bay? That’s a nice idea however shocks I just removed were marked as originals from 1987 on my 88 Carrera. However I just found attached image of similar looking item, hopefully I’m not correct
spacer for the two shocks that hold the rear engine lid up ?
Your picture is parts for a 356 or 912.
Of the suggestions so far i would think Icemans is the most plausable. Richard |
| All times are GMT -8. The time now is 07:37 PM. |
