Unknown part loose in engine bay
Tried on Renlist now to try here with all you gurus out there. Found a part floating around in engine bay while attempting fuel line exchange. Hopefully someone knows as last forum advice showed blitzed gearbox housing and image of similar part
Is the part threaded or is the interior smooth?
What year car?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
It almost looks like the spacer that goes under the throttle linkage in the 3.0 and 2.7 engines. I think those measurements are 37mm L, 13mm OD, 8mm ID.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Looks like the spacer for rear shock
Instagram: @TuitTech |
Rear shock spacer in engine bay? That’s a nice idea however shocks I just removed were marked as originals from 1987 on my 88 Carrera. However I just found attached image of similar looking item, hopefully I’m not correct
![]() I hope to god its not this item in picture |
spacer for the two shocks that hold the rear engine lid up ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Your picture is parts for a 356 or 912.
lake wales fla
Of the suggestions so far i would think Icemans is the most plausable. Richard |
