Mad scientist
Making the horn work with a quick release hub
Hi,
a while ago I got myself a quick release steering wheel hub from a company in England called Lifeline. It looked the business and wasn't too expensive. The downside was that the nice crested horn button didn't fit anymore, and there was no easy way of wiring it up. Not that I use it that often but I think it is illegal to not have one, and it fills up a hole in the center of the steering wheel. After some playing with a lathe, and a series of "don't works" I found a solution that looked quite neat. In addition to the QR hub it consists of two parts. One spring loaded contact inside a plastic housing (to the left in the image) and one brass pin in an insulating plastic base fitted to the back side of the horn button (to the right in the image). ![]() Since the QR hub bolted directly to the steering wheel there was no space left for the horn button, but that was fixed with an aluminum spacer. That spacer can be bought, but since I was already playing with the lathe I made it myself. ![]() So now the horn works, there are no ugly wires hanging where they shouldn't, and there is no need to disconnect any wires when removing the steering wheel. ![]() If anybody is interested I can provide drawings for the contact. It requires no destructive fitting. /Peter
'84 911 Carrera '91 928 S4 You can't make a racehorse out of a bull, but you can make an awfully fast bull. |
coolcavaracing.com
Hi Peter, looks realy good. could you PM me some more info? I had a look at the site, what type hub did you get?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing ![]() |
Mad scientist
I got the one called "Group N Touring Car" because I got the impression it was FIA approved. I am not entirely sure though, I'll have to check that. I'll send the drawings later. /Peter
coolcavaracing.com
Mad scientist
It depends. If your steering wheel is fixed to a separate hub the same way as Sparco and Momo steering wheels are, it will work. It fits the bolt pattern of at least those two brands, which is 6/70 mm.
/Peter
coolcavaracing.com
The steering wheel is fixed with three screws to the hub at 3,6 and 9 o'clock. So I will assume that it will not fit without some modifications?
Mad scientist
![]() /Peter
coolcavaracing.com
Yes, I can see that my fabrication skills will not be advanced enough to manage this project.
Ferdinand Magazine
Peter, I just love your style bro, this pic below is brilliant
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
Mad scientist
Another option is to get a Sparco or Momo hub and steering wheel. Quote:
/Peter
coolcavaracing.com
Yes, please PM me the number. I will have to do this at some point...
You could also check http://www.snapoff.com/
Dennis Johansen PCS 3413 Porsche 911 SC -83 SCWDP member #0004 Saab 900 -88 Vinga Edition |
This is a slick solution thanks for posting. Could you share what you used as starting point for the spring loaded brass contacts and plastic case? Thanks
- '86 Carrera 3.2 wide-body |
Kroggers, do they require that your race car has a horn in Finland? That was the only way I could imagine that you need a horn and that the wheel and hub needed to be FIA approved.
Laurence 1998 Specbox racer / 1998 Boxster / 1984 RSR tribute 1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa 1963 356B T6 Coupe / 1962 356B T6 Cabriolet Current projects - 1955 356 pre-a Speedster / 1964 356C |
Mad scientist
/Peter
Slippery Slope Victim
I just extended the two pigtails and put a quick connector between them that fit in the steering shaft. When you remove the wheel just pull the wire apart. Leave some slack. Worked fine for me.
Mike² 1985 M491 |
One last question, how did you secure/mount the delrin spring assembly within the steering column?
Oh, I see now, it just fits within the center hole of the splined quick release. Thanks.
Mine is less stock but still effective. Used Sparco radio buttons and wired to horns.
'75 Carrera, It's stock, I swear, scouts honor! |
