7783911's Avatar
doing first brake pad replacement
77 targa with A and M calipers
started last night and got pins and spring out. The old pads were almost glued in and took some effort but success. Refurbished pins and spring plate and spread calipers and squeeze new pads in (old ones were almost 1/4 inch thinner..almost worn to the backing)
Went to put back in...tight squeeze but success , installed redone pins and spring plate and tested by spinning disk and then apply brakes to reset caliper piston. spins but can feel the slightest resistance whhich i take as good.
Now the questions
there were no retaining clips as mentioned in many articles nor did i see any hole on the pin to insert? Normal or not? They are not listed as individual parts in any catalogue or in the PP parts lists...if anyone has the oem part number I would be appreciative, or can i use the same clips as used to hold the pins for the frunk hood struts?
in the rotor holes I saw two "wire spring clips"...at first i thought dpo had put retaining clips ther to hold and forget but these are thicker. Any idea what they are?
will do other 3 sides this weekend if pans go accordingly (ha ha)
I do know looking at the condition of exterior gaskets that a full caliper rebuild is in the future but will tackle that when funds and time permit. (I wish PP had a clearing house in Canada!)
thanks for any comments you can provide
Bob
Old 10-09-2020, 05:21 AM
porsher
aston@ultrasw.c's Avatar
On my 86 the pins have retainer springs in the form of an olive shaped split collet that grips the rotor holes.
Is that what you found? I have never know them to come off, they normally stay on the pins.
You may want to think about piston seals rather a full caliper rebuild, especially if they were hard to push back. When you get it all back together and bled, stand on the pedal for a minute or two and check to see that the seals are tight.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 10-09-2020, 11:51 AM
7783911's Avatar
interesting is that the fronts (a) dont use the clips, they have a small "crush" collar that holds the pins in place. Finished this weekend with some help from the forum. Used a brake lube on back of new pads and pins, re finished retaining spring plates and pins and painted calipers with porsche logo.
Looked like original pads in there,,all crusty and some thick glue on their backs. Also quite worn down compared in thickness to new textars
all in all, i learnt more about the car and enjoyed the time in the garage
thanks to all for helping with newbie questions
Old 10-13-2020, 04:12 AM
Bill Verburg's Avatar
The brake lube doesn't go on the back of the pads it is used to lube the sliding surfaces, aka edges of the pad and the pins. Yours don't have the vibration damper but otherwise is the same as shown here
also check to be sure that the piston notches are facing the correct way
Bill Verburg
Old 10-13-2020, 08:42 AM
