993 3.6 Intake valves on SC head need help!!!
Ok folks, seems like I`ve screwed up a bit (big time?)...
The story is, I have 82 SC heads, ported blah-blah-blah, for some reason (don`t ask) I thought that 50mm intake valves would be a good idea, so I got some. 50mm 8mm stem intake valves. Got the valves, guides etc, all sorted. At the point of assembly I`ve realized I can`t use my retainers with 8mm stem valves. Since 993 valves have their keepers closer to the end of the stem (8.8mm from the top) and original a bit further down (13.3mm) I can`t put them back together like that. So, what would be my best solution in this case?หวยลาว
1. 993 retainers? Not sure if they`ll fit.
2. New custom valves with the same stem length and diameter (keep 8mm) but with proper lock grooves (keepers repositioned)? Not sure if the retainers will fit.
3. New custom 50mm valves with 9mm stem (and plenty of work to re-machine guides etc)? Way too complicated.
4. Custom retainers? What exactly should be done to the design to utilize current valves etc?
I really need help.
Cheers
Old 10-14-2020, 11:25 PM
Call Don at EBS he's got what you need and will fix you right up
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-15-2020, 03:25 PM
WTH? someone just copied my post from a couple weeks ago
new kind of bots or what?
Old 10-15-2020, 10:33 PM
Bill Douglas's Avatar
Did you get it sorted Cat?
Old 10-15-2020, 10:44 PM
Yep, took some effort though. 993 retainers needed to be machined a bit to make them work with earlier springs
Old 10-16-2020, 12:07 AM
