1972 911T air intake hose question
Hi again folks.
I have a question about the hose that connects to the bottom of the air intake housing.
It was missing or removed from this car when I got it.
I bought a new hose and connected it to what I thought looked like the obvious place.
I am not sure where that connection comes from or goes to?
See photos.
Thanks,
Larry
Old 09-03-2020, 12:12 PM
Hi,
It looks to be an MFI, so I would think it's the drain hose on the air intake. I have a hole where your black hose is attached in the 2nd pict (1972S). That's where the drain hose (attached to the nipple in the 1st photo) goes. The small black hose is much longer than yours, and fed through the hole as the air filter housing is put in place.
Hope this helps,
Dario
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 09-03-2020, 12:59 PM
Thanks Dario,
I thought it must be a drain because the connection on the air intake housing is located at the very bottom.
Take care.
Larry
Old 09-03-2020, 07:03 PM
47silver's Avatar
That connects to a hose that is cinnected to a drain pipe on the starter side of the firewall. The drain pipe has a rubber seal that is fashioned to slowly let any liquid drain
Old 10-17-2020, 08:15 PM
