-   -   915 sudden shift problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1075847-915-sudden-shift-problem.html)
andy_braselton 10-16-2020 02:26 PM
Hello all,
I have an '84 with the 915 and since owning it haven't had any issues. Today driving home I was coming out of 5th gear and down shifting into 4th and had a little trouble getting it in 4th. This isn't abnormal. After coming to a stop I realized the transmission didn't want to shift as smoothly and began to feel loose and "clunky". After some more miles the car shifts into 1st and second fine but doesn't want to find 3rd. It is really difficult to find, almost impossible to transition into from 2nd.
This seems to have come out of nowhere.
There seems to be more play in the shifter when its in gear also.
The trans was rebuilt many miles ago and the car only has around 100K on it.
Any ideas
uwanna 10-16-2020 02:49 PM
Originally Posted by andy_braselton (Post 11067072)
Hello all,
Any ideas
Check for deteriorated plastic bushings in the rear shift coupler. That's my guess.
walt 10-16-2020 03:52 PM
Yes and the shifter bushing also. Hopefully that's all it is.
Antomero 10-16-2020 04:02 PM
Check your coupler bushings
BER 10-17-2020 05:29 AM
Agree with others...sounds like some of your shifter bushings had worn out.
Here is an article that explains which bushings need to be checked and how to replace:
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/37-Shifting_Improvements/37-Shifting_Improvements.htm
Geneman 10-17-2020 09:04 AM
in racing. we call it " notchy"
stevej37 10-17-2020 07:29 PM
Cool. :rolleyes:
pmax 10-17-2020 07:36 PM
Open up the cover plate and check if any of the nuts and screw are loose.
