Can anyone tell me whats disconnected here?
I'm a new owner, opened up the rear fuse area today to see if it was a fuse stopping the rear wiper from running and found these relays and this wire thats not connected to anything. Is this for the rear wiper possibly? These relays don't appear in the fuse list in this box in the bentley manual? Any help would be appreciated, thank you.
https://ibb.co/FhJHfWs
Old 10-17-2020, 02:56 PM
Old 10-17-2020, 02:59 PM
'73 911 T Targa
I think we're going to need a picture that's a little bit more of a close-up
Still here
pmax's Avatar
Doesn't look OEM to me. Did you check with the PO ?
Nice car BTW.
Old 10-17-2020, 03:06 PM
proporsche's Avatar
i`d say get rid of all of this extra wiring..show us the trace of it and we will help you..it looks like it does to the main harness ,on pic to the left i see blue connector-also to the right of the pick i see someone went into the yellow wire in the harness.....so strip it and let see it
It will only create a problem for you in the future
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-17-2020, 03:26 PM
Which part do you want a close up of? or do you mean because it only posted the pic of my car in the first pic, I uploaded all 3 it only posted one so I posted them below.
Old 10-17-2020, 04:01 PM
Ivan
So you dont think any wires coming off of that double relay is used for anything in the vehicle? Its a bosch relay, not sure if the parts numbers mean anything, im guessing they use those throughout the vehicle.
Old 10-17-2020, 04:05 PM
Heres some more photos, I tried following the wires that look to be still connected but they disappear from sight behind the fuel filter
Old 10-17-2020, 04:28 PM
While i'm here asking dumb questions, is this for one of the gauges, its also disconnected?
Old 10-17-2020, 04:30 PM
MBAtarga's Avatar
Looks like your car is an Euro model - what year?
All of the wiring in that plastic flexible tube is "suspect" - in that the factory did not use that product in the original wiring harness.
Edit - you posted about 6 or 8 new pictures before I typed my reply. My comment was on the picture of the rear left engine compartment picture.
Wire nuts (the orange wire nut) are also not stock...
Mark
'83 SC Targa - since 5/5/2001
Old 10-17-2020, 04:32 PM
Yes its am 83 911sc ROW, german car originally, been in the usa since 85, originally a pasha interior vehicle and delivered with the turbo tail from factory. I lover her. Just trying to get an idea of what all of this is and what belongs and what doesn't. Thanks for the help its appreciated.
Old 10-17-2020, 04:36 PM
The disconnected red wire on the chain cover is cold start injector Plug it to the thermal sensor.
The yellow runs to the 7th injector.
Note, with the key on the fuel pump is not supposed to be running
Bruce
Old 10-17-2020, 04:44 PM
Still here
pmax's Avatar
Any custom lighting ?
Old 10-17-2020, 04:51 PM
ROW '78 911 Targa
timmy2's Avatar
Likely a bunch of pollution control crap added when imported and federalized to mimic the Lambda system on US cars.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-17-2020, 04:55 PM
Nothing that looks custom. Everything else works on the vehicle except the rear wiper.
Old 10-17-2020, 05:29 PM
Anytime you see home electrical connectors used in an automotive application you know it is suspect.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 10-17-2020, 05:41 PM
Bruce
Not to sound stupid but is that what the yellow wire is attached to? Still learning, tried googling it but no other examples of that wire came up? Appreciate the guidance.
Old 10-17-2020, 05:42 PM
Still here
pmax's Avatar
Just a heads up, the fuse panel has live wiring... even when off.
Old 10-17-2020, 07:18 PM
Still here
pmax's Avatar
Thermotime switch , yellow goes on bottom the red to the top. Don’t know why it’s disconnected. If disconnected, the CSV doesn’t fire I believe but as someone else said , maybe it has a custom setup.
Old 10-17-2020, 07:24 PM
Thank you so much. Ill look into it.
Old 10-17-2020, 07:45 PM
