Help needed. How do a properly test this light?
How do I test this light with either 12v power or multi-meter? I do not have the attaching wiring harness. The bulbs are new. Any suggestions will be greatly appreciated.
Old 10-18-2020, 03:42 PM
proporsche's Avatar
you cannot just plug it into your 911 ?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-18-2020, 03:45 PM
I.e pull the harness attached to it and plug it into the harness on your 911
Old 10-18-2020, 04:00 PM
I do not have the harness in the car to plug it in. This light is for a later car and I am trying to adapt it to what was a seat belt light only. The original light has two wires only going to the seat belt light and that wiring from the seat belts to the relay is missing, so I have not been able to test the original light either. Thanks for the replies.
Old 10-18-2020, 04:56 PM
Timmy will know ...
Old 10-18-2020, 05:36 PM
Using this schematic might help
- bus 15 = 12V (when key on ACC I believe)
- 31 = GND for the circuit
- the parking break switch is actually connecting 'HB' to ground
- the seat belt relay connects L to ground for some time when the seat belt is not in
- the pin 30 is an always on power I believe
- don't know where pin K takes it input from
1985 Carrera 3.2
Old 10-19-2020, 12:23 AM
Image didn't show
1985 Carrera 3.2
Old 10-19-2020, 12:26 AM
Thanks FrankM. I think pin K comes from the "stop light" switch since the light has three options-seat belt, parking brake and brake light. I appreciate that you took the time to reply and help. Learning fast how to read a flow diagram.
Old 10-19-2020, 07:17 PM
