7783911's Avatar
correct wiring for targa dome light
Can someone (Timmy?) confirm the correct wiring for the targa done light
Old 10-20-2020, 03:27 PM
ROW '78 911 Targa
timmy2's Avatar
If I had one in my hand I would meter it out for you.
3 positions.
One will not conduct power, Through the lamp.
2nd will only go from power to ground wire,
3rd will go from power to door switch wire.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-20-2020, 04:43 PM
7783911's Avatar
Thanks Tim
Yes, that's exactly the behavior as I expect with regards to the 3 positions of the switch, on off, doored
but are the arrows correct since the one constant is power it makes sense to be the left sided tab to the bulb while the 2 right sides provide the on and doored ground?
Old 10-20-2020, 06:12 PM
'73 911 T Targa
I’m not 100% sure, but I think you’ve got the grounds reversed.
I just put one of these in and I wish I could remember.
You should get continuity between the constant ground lug, the frame and the buttons on the ends.
Old 10-20-2020, 06:34 PM
