Mfi Mechanic needed in northeast.
I have a 1973 911e mfi. Have had a few people work on my car over the last 10 years and no one has been able to get it right. I am looking for a true guru of the MFI car. Do you know of https://snaptube.cam/ 9apps anyone you would suggest. I have given up trying to figure out myself. Any help would be appreciated.
Been here a while
where in the northeast.
Gaspare at Gaswerks in Paramus is amazing Auto Associates in Canton CT is also on the list....if you are in Boston or Phili, lots of choices
looking for 1972 911t motor XR584, S/N 6121622 |
Another vote for Auto Associates in Canton CT.
1979 Indishrot 930, Rudolph ------------------------------------ "Dad, buy it! Real race cars don't have sunroofs." |
Exotech in Plaistow, NH. Mark Nadler can't be beat.
Send the pump to be rebuilt and setup by someone like mark jung. That eliminates the most critical component from the list of items that can negatively affect the engine operation.
Everything else is doable by a home mechanic though you do need some tools like the air flow sensor, and i would get an sir fuel mixture gauge. |
Thoroughbred Motorsports Inc
Corry pa |
It seems that people are willing to advise and some have already chimed in.
It’s a little rude that you’ve so far refused to answer where you’re located though. If the help is appreciated then responding to people should be easy. RR Quote:
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
You need an AFR meter. Then it's pretty easy.
Chris 73 911 E |
Afr’s are the only way. I put one on each bank, really did not need 2 after pump was rebuilt. I wss worried about condensation ruining the srnsor so i put a switch in the circuit and keep power off until the engine warms ip a bit
Navin Johnson
Bot or scammer wanna be..
Two posts in less than a year since it joined.. Didn't the incongruous "Snap tube" links in the middle of each of the post raise your eyebrows?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
if you get stuck, send me the pump and i will take it to where porsche has the pumps rebuilt myself. I drive a 73 MFI TE myself and it runs perfectly.
