markmalin's Avatar
How do i determine if my car has Boge or Bilstein?
May be a silly question, but I don't understand how to determine if my car has Boge or Bilstein struts. This is an 85 Carrera. They are green, but there is no label on them. I don't want to buy the wrong inserts.
Humbly,
Mark
Mark - New Glarus, WI
Old 10-28-2020, 06:43 AM
Humbly,
Mark
green is for bilsteins, i'm assuming they are not boge painted in green
Old 10-28-2020, 07:01 AM
markmalin's Avatar
Grazie!
Old 10-28-2020, 07:02 AM
If bilsteins are in boge struts, the dust cover is green and the strut is black. Most Carreras came with boge. Bilsteins have a big rollpin through the bottom of the strut.
206 637 4071
Old 10-28-2020, 09:23 AM
Bill Verburg's Avatar
Sort of hard to see due to the road grime but Bilstein's have an external pin that locks the insert rod to the outer casing. It can be seen here just above the ball joint
Bill Verburg
Old 10-28-2020, 10:23 AM
markmalin's Avatar
Ah! Thanks. Mine are certainly green, but I'll have to look for that pin.
With Bilstein's, do you tap the pin out and the insert pulls out, then?
Old 10-28-2020, 12:39 PM
yes
Bill Verburg
Old 10-28-2020, 12:45 PM
nothing to see here
Steering rack gaiter in need of renewal?
Old 10-31-2020, 03:20 AM
