911 oil fitting
does anyone know what the oil fitting in the photo is for?
never seen it on 911..where did you get it from?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Well it looks like a 30mm fitting.. Could be for a thermostat or maybe 72 oil system
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Might be a 935 part? With an O ring in that groove it might fit into one of the cylinder head/valve cover area oil return holes in the crank case. The cylinder head area was drained by a Y tube into just one of the holes on the left side. The cylinder out on the tab looks like it fits over an 8mm stud to hold things in place. The oil pump for this system was modified to have a second scavenge outlet through the nearby hole. Can't say I know of a stud in that vicinity to do this, but drilling and tapping aren't hard to do.
I |
'89-94 964 Fig 1-01-10 #54 964.207.317.00 Adapter (below case filter console) Qty: 1 PCNA List: $140.99
Fitting ID
When you order a replacement 964 engine case, they don't come with threads in the case for the original oil inlet supply fitting. This fitting slip fits into a 993 case but retains the threads externally for your supply oil line.
thanks much!
