83’ fuse noob - Radio? Oil Cooler? Broken plug?
Hey,
I recently purchased an 83’ 911SC coupe. It’s in pretty solid condition but has a few things to be resolved.
(3) questions...
- Am I missing my entire oil cooler fuse?
- is the #4 (radio) fuse blown?
- In the engine bay what is this broken orange plug?
Old 11-03-2020, 01:10 PM
Full Send Society
The number 4 fuse is just spun around. Twist it and you'll see if it's blown.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 11-03-2020, 01:17 PM
fred cook's Avatar
1) Never heard of an oil cooler fuse! The added in ATO fuse could be for a aftermarket oil cooler fan added on.
2) #4 fuse from the rear looks to be turned around backwards. Turn 180 to check.
3) That is the connector for the O2 sensor. A common problem. If the wires are intact, you can fix with some epoxy or replace the unit.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 11-03-2020, 01:22 PM
Ha! I turned the #4 around and it was not blown, which is strange because the radio and some of the cabin lights don’t turn on at all.
I should have checked myself, the inside of my lid (which I just found) says relay fuel pump I
Thanks about the O2 Sensor!
Old 11-03-2020, 01:32 PM
WOW
Old 11-03-2020, 01:39 PM
