1980 911 SC Electrical Issue
I had my car out for a drive this morning. After about an hour, the tach started flopping around and after a few minutes quit entirely. Then the odometer stopped working, but the speedometer was Ok. Then the turn signals weren't working, at least the light wasn't flashing on the instrument panel.
After I got home I let it sit for about an hour and then went to see what else wasn't working. Now everything is working so I'm guessing a loose wire??
Where should I start looking?
1965 356 SC
1980 911 SC
Old 11-01-2020, 06:51 AM
ROW '78 911 Targa
timmy2's Avatar
Start with checking the battery terminals are tight. Then move on to checking/cleaning fuses, followed by engine ground strap and body grounds.
Check your alternator voltage output. At idle and while driving.
Lots of posts on how to check all of these items.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-01-2020, 08:43 AM
Thanks!
1965 356 SC
1980 911 SC
Old 11-01-2020, 08:59 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Well, there's nothing electrical about the odometer, so there may be more than one problem. I'd look at grounds. The main ones are battery to body in the trunk and body to transmission underneath by the passenger rear wheel. After that there are several other grounding points that could be a source of your problem.
But Dennis is the expert, so believe him first!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 11-01-2020, 09:45 AM
ROW '78 911 Targa
timmy2's Avatar
Agree odometer is a separate issue.
Lots of Intelligent people know about electrical problems on these cars.
Dru is one of them...
Dennis
Old 11-01-2020, 10:24 AM
Might pull the tach and speedo and do some checks. I shorted some stuff out on the dash through my own carelessness and it caused somewhat similar symptoms minus the odometer issue you're seeing.
See if any wires are shorted to ground as a start. There should be a brown wire that is spliced in several places behind the gauges.
Old 11-01-2020, 12:58 PM
Walt Fricke's Avatar
Nothing electrical about the odometer? After the change from cable speedometers/odometers, the odo is some kind of solenoid which fires after X pulses from the speedometer sensor in the transmission. I believe he is concerned with his SC, not his 356.
I'd check the battery. If, perchance, the voltage regulator has quit working, its voltage will keep dropping. When that happened to our 3.2 (at night, of course), letting the car (which quit) sit a while allowed a few more miles of driving - it seemed the battery could somehow do a bit better after a rest - though a flatbed was still needed. But some systems may be more sensitive to voltage levels than others. I think the tach is one.
But it could just be a bad ground - more resistance as it heats up - or loose connection which expands a bit with heat.
Old 11-01-2020, 06:41 PM
Dennis, your diagnosis was correct.
New alternator solved the problem.
Thanks for your help and knowledge!
1965 356 SC
1980 911 SC
Old 11-03-2020, 10:45 AM
