83 sc, glovebox light with switch on light
My glove box light has a switch on it, the switch is broken, id like to replace it but I can't find one for sale used let alone new that has the switch, will the non switch version work in place of this type of light? Anbody else have a switched light on the glovebox?
Our host has the "button" switch (on/off) in the catalog for $8.50. I couldn't find the three-way slider switch, but I'm sure it's available if you call. If it's the bulb, those are also in the catalog.
Be very careful working with this glove box light.have seen the making a big el.short while removing ..Disconnect the battery and make sure your black wire is nowhere near the body -metal
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
