Center console fader plate broken need replacement
Hi, in my 84 Carrera the part that holds the fader and the 2 AC knobs has cracked and the fader now hangs loose. I tried to source the replacement part but no luck it seems to be discontinued. All I could find was a fader trim plate but I don't see how I'm gonna make it fit.
How would you guys go about it? Thanks! This is the part that's discontinued: 91155216900 Part #5 in this diagram: http://forums.pelicanparts.com/uploa...1604601772.jpg |
This is how I repaired mine. I actually replaced the Fader with a rocker for the power antenna, but leaving the Fader would be just as easy. Not a restoration, but a decent fix that looks clean and is not noticeable.
http://forums.pelicanparts.com/porsche-911-technical-forum/1024926-yet-another-conti-radio-install-thanks.html |
It is sandwiched with the stem nuts by the AC controls.
Not a restoration type fix, but I was unable to find a good replacement part. http://forums.pelicanparts.com/uploa...1604663673.jpg If I ever have the console apart again, I will make a new plate that incorporates the USB jack at the bottom. (And possibly the Kuehl AC status LED) http://forums.pelicanparts.com/uploa...1604663802.jpg |
Nice,
I should've ordered that head unit, I just changed mine to a cheap Sony but it was my first install and didn't wanna blow anything up that's too expensive. And it does what it's supposed to do very well so I'm happy. Speakers are next. |
Kinda did the samething.........
i gutted the knobs and put the USB's inside the knobs..... looks ok.
http://forums.pelicanparts.com/uploa...1604690418.jpg http://forums.pelicanparts.com/uploa...1604690418.jpg http://forums.pelicanparts.com/uploa...1604690530.jpg http://forums.pelicanparts.com/uploa...1604690530.jpg i also added bluetooth and a microphone..... tried to hide it. all 3 things work perfectly... USB, BT, and Microphone. |
Now that is slick... ^^^^ with a Livestrong bracelet and an Alpine head unit....love it!
Plate.
Gerry |
thanks 4flyboy.................. i appreciate that. i thought it came out pretty clean, but i was biased obviously.
our fellow pelican, my friend gave me that livestrong bracelet 10 years ago..... i like the idea of living strong. a 1974 911 with some modern bits to it...... happy with it for sure! |
Found one through Einmalig, thanks for the help guys
| All times are GMT -8. The time now is 02:05 AM. |
