Turn signal frozen on only when headlights are on
The left turn signal does not blink when the headlights are on but does blink when the headlights are off.. anyone have this problem and know why?
Old 11-05-2020, 03:45 PM
check the ground for that light assembly. when the headlights are off the current for the turn signal will flow back through the running light and and ground through the other lights on that circuit. when the headlights are on, that path is interrupted so you won't have enough current flow through the flasher relay to get it to flash.
Old 11-05-2020, 06:54 PM
Great, I’ll look.
Thanks!
Old 11-06-2020, 04:11 PM
