69E hose routing
Does anyone have a picture they can share of the exact routing of the hose that connects from air filter snorkel to oil tank flange? There's two other hoses in this area, not quite sure the proper routing. The one going to air filter snorkel I believe tucks in behind the oil fill cap, however, and I'm using the correct hose, it is tight to try and shove past the oil fill cap, even after removing the cap. It seems I will crimp the hose trying to force it behind the oil fill tube.
Old 11-13-2020, 07:20 AM
