| toddetch |
11-14-2020 07:36 AM |
Installing CR alternator and electrocooler AC - replace A/C crankshaft pulley?
Hi all,
My COVID/winter project is sitting in my garage waiting for me to get started - the Classic Retrofit upgraded alternator and the electrocooler A/C. My car had factory A/C that didn't work when I bought the car and the compressor, condensers, and all the hoses have been removed. The dual belt crankshaft pulley is obviously still there. I don't like to replace things that don't need replacing, so I'm wondering if there are compelling reasons to replace the crankshaft pulley with the non-A/C version. I know one advantage is weight - if I am reading correctly the A/C dual belt pulley weighs 4 pounds vs. the non-A/C pulley which weighs 3 pounds. Is the amount of work worth 1 pound? Are there are other reasons to replace it - I don't know, like the way it balances or something when only using one belt? Of course, you can go further on the weight-saving side with the Rothsport aluminum pulley. Anyway, I'm just wondering if this is something that I really should do or if I should leave well enough alone and use the existing pulley.
Thanks!
Todd
