DME for a 3.0 help
My engine ID #. Is: 64D0990
I can get a DME with the harness. Here is a pic. Will this work with my 3.0? Thanks.
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 11-16-2020, 04:36 PM
DME for a 3.0?
Ass-engine Nazi slot car -- PJ O'Rourke
Old 11-16-2020, 04:58 PM
That's an O2 computer for the frequency valve, which an 80-83 SC needs to function correctly, powered by a relay that sits beside it.
206 637 4071
Old 11-16-2020, 05:08 PM
lake wales fla
Well to start with thats not a DME control unit it is a Lambda control unit for Oxygen sensor regulation. 64D is a 930/16 81-83 USA 3.0 SC and would take a 911 617 103 00
The control unit you have pictured is for 86-89 930 USA car and will not work on your engine.
Richard
Old 11-16-2020, 05:15 PM
Richard
Ah. Ok. That’s helpful. Thanks.
1988 535i
1987 535is
1973 bronco ranger
Old 11-16-2020, 05:31 PM
Still here
pmax's Avatar
You need the 037 or 055 I believe.
Last 3 digits of Bosch number.
Old 11-16-2020, 06:43 PM
Do I need the little box as well? What is it?
1988 535i
1987 535is
1973 bronco ranger
Old 11-17-2020, 03:58 PM
Still here
pmax's Avatar
https://jimsbasementworkshop.com/CIS/pages/comp_page.html
The electronics box provides cold starting warm up enrichment in addition to the cold engine enrichment provided by the WUR.
A different switch on the throttle valve was added. This modified the system operation in the following way: There are now a total of three switch contacts
Old 11-17-2020, 05:30 PM
