Sudden Clutch Play
I have a 1977 911 with a manual clutch. I now have play in the clutch cable. The nuts are still tight and the wedge is still in place. The clutch pedal is good.
Did the clutch tube break at the firewall?
Old 11-26-2020, 08:13 AM
Maybe, could be broken clutch fork or sheared pin in pedal cluster, or any other number of things in the long chain of things that must work in a 911 for good clutch action.
Old 11-26-2020, 09:46 AM
I’m going to look at the Bowden fitting on the transmission next.
Old 11-26-2020, 10:08 AM
It's a 914 ...
stownsen914's Avatar
If you are able, have a helper exercise the clutch while you watch the various parts. Looks for parts that are moving when they shouldn't.
Old 11-26-2020, 03:15 PM
Could it be the shifter fork bent?
Old 11-26-2020, 04:25 PM
Slippery Slope Expert
Steam Driver's Avatar
It may be the cable itself breaking. When a stranded cable begins to break it does so a strand at a time and begins to unwind and “stretch.”
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 11-26-2020, 06:16 PM
It was the clutch fork arm, this is the second one in five years.
Old 11-27-2020, 10:19 AM
