-   -   While engine is out to do list help (http://forums.pelicanparts.com/porsche-911-technical-forum/1079640-while-engine-out-do-list-help.html)
stubble88 12-01-2020 08:43 AM
I bought this motor. Was running over a year ago. Has sat since.
1983 3.0 stock ~86k miles. Going into 68 chassis
Currently this is what I’m thinking of doing while motor is out:
-adding Weber carbs
-adjusting valves ( new gaskets). Anything else?
-flywheel seal and bearing
-oil tubes
-new plugs
-has the braided wires. Should I replace them?
-recurved or older distributor
What else should I do or inspect while it’s out?
Thanks.
winders 12-01-2020 09:02 AM
Get PMO carbs instead.......
stubble88 12-01-2020 09:07 AM
I know. I was looking. But I found some freshly rebuilt Weber’s for $2200.
PMO’s would have been $5k.
Charles Freeborn 12-01-2020 09:40 AM
Not terribly familiar with '83's but if it's a CIS engine you won't realize the true potential of the carbs without changing pistons and cams.
VFR750 12-01-2020 12:50 PM
Replace the rubber seal. It’s installed in the chassis and seals to the engine tin.
Surprising how stiff and brittle it gets with time.
walt 12-01-2020 12:59 PM
Replace the oil pressure switch and the breather gasket in the triangle area. Upgrade to hydraulic chain tensioners if not already.
gomezoneill 12-01-2020 03:49 PM
It's wrong to put carbs on a CIS engine. It wont work. You'll need different cams and cam timing.
30westrob 12-01-2020 04:21 PM
Have you thought about cylinder studs? Rob
fanaudical 12-01-2020 06:50 PM
You might also think about stuff to do on the car while the motor is out. Fuel lines, shifter bushings, any in the tunnel is easiest to address when the motor is out. Rear swing arm bushings, too.
al lkosmal 12-01-2020 08:58 PM
this....
do this......
http://forums.pelicanparts.com/uploa...1606888610.jpg
regards,
al
stubble88 12-02-2020 03:22 AM
As for the chain tensioners. Is this a must do at any mileage? It’s just a bit costly. How often do these fail on the pre 84’s?
walt 12-02-2020 04:42 AM
This was the first mod I made when the car was purchased knowing a failure of the tensioner could be catastrophic to the engine. I don't have any experience with the tensioner guards but they are very inexpensive and look easy to install. I would certainly consider this as a minimum.
Edit: They used to make a repair kit for mechanical tensioners but they may be NLA.
OldSpool87 12-02-2020 05:03 AM
You may want to smoke test the intake and look for leaks. Working on seemingly simple CIS components with the engine in is a pain.
stubble88 12-02-2020 07:28 AM
Forgive my ignorance. Still new to this motor.
But do these oil lines indicate that I already have the upgraded tensioners?
http://forums.pelicanparts.com/uploa...1606926457.jpg
http://forums.pelicanparts.com/uploa...1606926476.jpg
timmy2 12-02-2020 07:34 AM
Yes, tensioners are upgraded to oil fed type.
stubble88 12-02-2020 07:36 AM
Oh my. This is a big relief. I was stressing seeing the $1800 kit on pelican. Nice!! Thanks Dennis
walt 12-02-2020 12:25 PM
As for your question on the braided wires. I'd leave them at least for now, easy enough to change out later after the engine is installed.
3rd_gear_Ted 12-02-2020 03:11 PM
Replace 37 year old fuel pressure regulator and twist the crimp fittings on all the associated hoses, if any fittings spin replace all 3 hoses.
otto_kretschmer 12-02-2020 11:14 PM
I have my 76 on jackstands right now. I havn't driven the car in a decade so I'm dropping the motor to inspect everything and replace what doesn't look good.
I got the axels out today and I was looking at the grease. I replaced the boots maybe 13 years ago and cleaned and packed the cv joints. The boots and grease looks ok and I probably can get away with just bagging the joints and reinstalling as is..
but then I started thinking about the rear wheel bearings. They're probably still packed with the original grease from 1975.
I'll just clean, inspect and repack everything now.
NY65912 12-03-2020 06:10 AM
Years ago I bought a nice '80 SC with 46mm PMOs and SSIs. I put in DC40 cams, 10.5 to 1 pistons and that car screamed. Not so much for the stock 3.0 and PMOs. Oh, don't forget that the distributor needs to get recurved.
josephvman 12-03-2020 12:40 PM
Install a pop-off valve on the air box. Check head studs. Fuel lines. If the car has a/c or if you want to install it it’s probably easier to do with the motor out.
JJ 911SC 12-03-2020 02:21 PM
First thing should be; get a Credit Line :D;):D
midnight911 12-04-2020 04:02 PM
Must have a picture taken with you in the engine room.
