-   -   defrost light assembly switch not working. '85 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/1079648-defrost-light-assembly-switch-not-working-85-911-a.html)
jgurnari 12-01-2020 12:25 PM
I tested the switch with a circuit tester and it is getting power, AND I tested the bulb, it too works... but the bulb is not lighting when inserted! Cant figure it out...any ideas?
'85 911
Thankshttp://forums.pelicanparts.com/uploa...1606854072.jpg
76FJ55 12-01-2020 01:20 PM
are you grounding the assembly? that brass collar around the lower screw hole is the ground contact for the light. make sure you are getting a good ground connection when you mount to light assembly to the chassis.
jgurnari 12-01-2020 04:43 PM
I am relying on the screw that goes into that brass collar to ground on the chassis. It Seems to be screwed in but obviously not grounding for some reason. Maybe some carpet is being pulled into the screw hole as well.
jgurnari 12-02-2020 05:31 PM
It was corrosion! All good now. Thanks
ErrorMargin 12-07-2024 09:37 PM
Do you recall what kind of screw is used to attach the light to the floor? Is it a sheet metal screw or a machine screw? What size?
I checked the PET but I could not find it.
