reesestewww's Avatar
Porsche Crest Brake Pad And Rotor Thickness????
Does anyone know the specs for the OEM thickness of brake pads and rotors, front and rear, for a 911 SC
Past:
04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne
Old 04-25-2003, 07:42 AM
Formerly bb80sc
Vipergrün's Avatar
New thickness would be 20mm front and rear, replacement thickness is 18.5mm front and 18mm rear per Pelican. Sorry, don't know about the pads.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-25-2003, 07:52 AM
makaio's Avatar
New pads should be 10mm. Replace at 2mm.
Old 04-25-2003, 08:11 AM
Replace Pads when they get to 2mm or when they loose 2mm???
Past:
Old 04-25-2003, 09:14 AM
IROC's Avatar
Depends on how much you enjoy replacing brake pads...
In theory, you can let them wear down until there is only a thin film of brake pad material left, but not only do you risk going too far and damaging the rotors, you're also allowing alot more heat to go into the calipers during braking (as the pad material acts as an insulator) and that can have unwanted consequences like boiling your brake fluid and your pedal goes to the floor at the wrong moment.
Mike
Old 04-25-2003, 09:21 AM
Bill Verburg's Avatar
If you track the car replace pads before they are 50% worn for the reasons IROC mentioned. For street use take em down till you feel guilty.
Bill Verburg
Old 04-25-2003, 02:25 PM
