Harpo's Avatar
wheel spacer dimensions
Good morning everyone,
Does someone have a wheel spacer they could measure the ID and OD? The wheel stud pattern is 5x130
Old 12-08-2020, 04:47 AM
djpateman's Avatar
Stud pattern had better be on 130mm
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-08-2020, 05:54 AM
Harpo's Avatar
Thanks for that. ID & OD still tbd
Old 12-08-2020, 06:38 AM
Here you go, a hub centric Porsche part. Measured some no names I have and they are within 1/8" of these inside and out.
Old 12-08-2020, 11:23 AM
Porsches are hubcentric, so if you're wider than 7mm or so you want the "lip" that fits over / under the 71.5mm centerbore.
The ones that are on ebay for like $20 a pair work fine, I've used several widths over several years.
Matt - 84 Carrera
Old 12-08-2020, 12:15 PM
