Help with door hinge pin tool
Does anyone have the tool to remove the door hinge pins for the early 911’s? It is tool number P260. I need the dimensions of the shaft length and the distance from the end of the shaft to the stop that is welded to the shaft. Thanks.
Old 12-04-2020, 09:08 AM
Bump
Old 12-05-2020, 07:26 AM
cycling has-been
bkreigsr's Avatar
You don't mention what year your 'early' car is.
I tried to knock the pins out of my 76 with a dedicated pin removal tool.
It is a very violent procedure, especially if they have never been removed. (I worked my up to a 3 lb sledge before giving up.)
After I convinced myself that I was going nowhere and causing permanent damage to the door-jam sheetmetal, I removed the doors by unbolting the hinges.
YMMV - my 76 was a 20 yr garage find.
Bill K
Old 12-05-2020, 11:03 AM
My car is a 69E. I loaned my tool to a guy who somehow managed to break it. He tried to repair it by welding it back together. I need to have a new shaft made but need know the correct length. Kevin
Old 12-05-2020, 02:37 PM
I need to revise my original post. The Porsche tool number is P290. Please help.
Old 12-06-2020, 08:55 AM
When I removed my door I used a floor jack with a piece of 2x4 on the foot so as not to scratch the paint on the bottom of the door. This worked great to support the door and
then I just removed the bolts that fasten the hinge to the car.
Old 12-06-2020, 09:12 AM
Harpo's Avatar
Jimmy makes a nice door pin removal tool that he sells. I will look for his contact info
Old 12-06-2020, 01:41 PM
Harpo's Avatar
sending you a PM with Jimmy's email
Old 12-06-2020, 03:38 PM
I do the same thing when removing the door, but my hinge pins wore out. I tried everything to get them out without success. I put up with the worn pins for a couple of years while I tried this tool and that method - nothing even budged the pins. I finally read a comment by John Walker that said he just uses an air impact hammer. I bought an inexpensive air hammer and it removed the pins in about 5 seconds without any damage to the door or hinge. After all the trouble I went through, this was really easy - and now I have a new tool that I can use for other jobs.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-07-2020, 06:10 AM
I just popped them out from the bottom with a large drift and a hammer. I put in new bushings and the door was great after that.
Old 12-07-2020, 12:21 PM
Thank you everyone, but what I need is the length of the factory shaft and the distance from the end of the shaft to the slide stop. I have the thread on pin end. I bought this tool a few years ago from Baum tools. Thanks, Kevin
Old 12-07-2020, 03:43 PM
Polycab is dedicated to make life better with an extensive range of electrical wire and cables that are manufactured in plants using latest technology (electron beam/buss co-kneaders) with world-class materials under strict quality assurance procedures with total traceability of in-house or approved supplier materials and throughout production processes. The Polycab R & D center is the backbone for compound and metals innovative developments to provide optimum power, weight savings coupled with superior fire performance that assures compliance with all local and international standards validated by comprehensive testing at polycab internal NABL accredited lab and external third-party labs.
Old 12-07-2020, 05:28 PM
