DIY brake pad replacement ’85 911
I can’t seem to find a DIY thread on how to replace my brake pads. 1985 911. Thanks
Old 12-08-2020, 05:24 PM
Thread Killer
Teutonics's Avatar
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/46-Brake_Pad_Repl/46-Brake_Pad_Repl.htm
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 12-08-2020, 05:42 PM
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 12-08-2020, 05:44 PM
Thank you Alan! May attempt it
Old 12-08-2020, 05:45 PM
Any recommendations for which pads to use on ‘85 911?
Old 12-08-2020, 06:25 PM
These cars are extremely easy to change pads on. It can be done during a pit stop during a race.
Old 12-08-2020, 06:48 PM
HarryD's Avatar
If you don’t have the book. https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/46-Brake_Pad_Repl/46-Brake_Pad_Repl.htm
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-08-2020, 07:18 PM
Depends on how you use your 911. For street, Mintex will do. For performance street, Porterfield R4S.
Old 12-08-2020, 07:57 PM
Thanks all!
Old 12-09-2020, 06:09 AM
MBAtarga's Avatar
+1 on Mintex
Mark
'83 SC Targa - since 5/5/2001
Old 12-09-2020, 06:22 AM
MBAtarga, you agree Mintex is a good product? Thanks
Old 12-09-2020, 06:59 AM
It is super easy to change the pads. Be sure to inspect the rotors carefully. If they have a large lip or groves you may need new rotors. Most often pads alone are fine.
On a scale of 1 to 10 it is a 1.5 at most. About like an oil change in difficulty.
Old 12-09-2020, 07:03 AM
Glen are you familiar with Mintex pads? If so your thoughts. Thanks
Old 12-09-2020, 07:09 AM
found out about needing to buy new “glue on censors” with new pads. How do they glue on? Is this going to be more involved than first thought?
Old 12-09-2020, 07:29 AM
Location: behind the redwood curtain, (humboldt county) california
brake fluid
dont forget to keep an eye on the brake fluid level when pushing the pistons back in the calipers, or you could have a nasty mess.
If you haven' changed the fluid in a couple of years, this might be a good time to do it.
Old 12-09-2020, 12:07 PM
HarryD's Avatar
I have been using Mintexes on my 1973 for a long time. Quiet, minimal dusting, good stopping power, adequate for my level of Autocross and HPDE events.
Harry
2020 MB E350 4Matic
Old 12-09-2020, 04:57 PM
HarryD's Avatar
Yep. made that mistake once. Big mess.
I do mine every year, takes about an hour and a liter of fluid with my motive bleeder.
Harry
2020 MB E350 4Matic
Old 12-09-2020, 04:59 PM
HarryD's Avatar
While this may sound like a grumpy old guy, You have several threads going on this topic. We can help you better if you consolidate them into one.
https://forums.pelicanparts.com/porsche-911-technical-forum/1080342-tried-duralast-semi-metallic-brake-pads.html
https://forums.pelicanparts.com/porsche-911-technical-forum/1080312-pad-replacement-glue-brake-sensor-85-911-a.html
Harry
2020 MB E350 4Matic
Old 12-09-2020, 05:11 PM
Tags
brake pads
