				attach door panel clips
			the door panel clips are larger than the hole in the new door panel, how do i attach the clips without destroying the hole provided ?
				the old panel was “soft” from age and long time wear, which made it easier to manipulate and the clip spun in. are there other, more compatible, clips I should use? 1985 911 coupe
			Just did this. Screw them in like any other door panel clip, pliers help. May have to bend one of the 'teeth' to get it started easier like I did.
			ok, thanks  didnt want to ruin the hole.
