77 Restorer
'77 911 rear sway bar removal
Hi all:
Trying to remove the rear sway bar off my '77 911 targa. Easy enough to take out the 12mm nuts, but the ball joints I cannot find a way to remove! I searched the forums and found Wayne's old article, but cannot figure out how to get enough leverage to 'pop off' the ball joint apart. Any hints to guide this noob on separating the ball joint apart? Thanks! Bert
Bert 77 911 Targa (Maize, or Talbot yellow as the case may be) 04 C4S Cabriolet (sold) |
cycling has-been
I usually just stick a strong broomstick in there and pry it off.
Pre-lube and coat generously. Reinstall using a shorter broomstick and a BFH, again, coat liberally with grease of your choice. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 01-08-2021 at 12:10 PM.. |
77 Restorer
Thanks very much Bill - much appreciated!
I would rather be driving
I pry them off with an open adjustable wrench levered on a hammer handle.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
77 Restorer
Excellent! My simple brain can definitely follow that direction! Thank you sir!
A well placed long crow bar reduces muscle effort and crunched knuckles.
77 Restorer
Thanks! With these suggestions I better be able to remove said bar - much appreciated.
Remove the end links from the bar and then just twist them upwards like the arrow and they just pop right off.
77 Restorer
So if I understand correctly, remove the cotter pins to free up the drop link, and just twist?
cycling has-been
Whatever you do - don't bend them or alter their alignment. If you do you, risk having them popping off every time you take a turn at speed.
Also - they are handed - right and left - both have specific angles of attack. Be careful if you use a crowbar. Steel has a tendency to deform the surrounding sheet metal.
73 911T MFI, 76 912E, 77 Turbo Carrera |
One method: Place tip of your prying device under the metal lip of the ball cup, then find/create a fulcrum point nearby (ideally near the ball) to lever the drop link off.
Yes, when you twist up the top of link will contact the stud and pop itself off. The plastic is relatively soft but warmth helps, you should be OK at room temp in SoCal, I was in NorCal. When I R&R'd the ball cup bushings I placed them in hot water (microwave a coffee cup full of water and bring out to garage) for a few minutes and they went out and in easily by hand Last edited by eastbay; 01-09-2021 at 09:05 AM.. |
77 Restorer
77 Restorer
Great; thanks. That makes sense.
77 Restorer
77 Restorer
Just wanted to thank everyone for their comments. By bending the drop link up after displacing the sway bar towards the back of the car, and then using a large adjustable wrench levered on a small hammer to push up the link to it's furthest point, with just a bit of force the ball joint popped off! So basically I combined a couple of suggestions to get this off in the most facile way this noob could! I hope this helps someone else in the future - it's the power of all of your experiences come together. Thanks again!!
