front fender and cowl seals
Hi,
I have a 964 and am looking to replace the rubber seals that go between the top of the fender and the cowl with a wider then stock version. Does anyone know if they make this product and where I can buy it? Thanks, David |
It's called welting you can buy it here on pelican.why would you want thicker than stock???
Fleabit peanut monkey
Does Pelican have the wider ones? Pretty sure I bought mine from here in the way back.
1981 911SC Targa |
Thanks guys.
Someone painted the cowl and fender without removing it. I want to remove the old ones, wet sand, polish and then replace with wider version to hide any sins. I saw 2 versions 4.3mm and 6.5mm (1/4”). What was the width when new? Anything wider then 6.5mm? |
Looks like both sizes are still available.
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=Fender+cowl+seal
Joe Frantz 73 911 T |
small piece of welting to be replaced
Should be one of the ones on this page:
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=seal+fender+extension |
Location: behind the redwood curtain, (humboldt county) california
While yoou are in there....
While you are in there, check for frunk gutter rust around/under the weatherstrip for the hood. You could feel along the underside of the frunk gutter for any roughness, possibly indication rust through.
I had some serious perforation, which allowed rain to soak the passenger floor carpet. On a similar note, i found rust through between the L fender and the body of the frunk. Water from above and below. Good Luck, chris You really don't want to see the pictures :-( |
Seal - Fender Extension Panel
On the right track! I dont see left front LOWER. Wondering if upper means both upper.. same one fits upper and lower of that panel.
Titanium User
Lower seal fender extension 911 503 325 00
https://www.pelicanparts.com/More_Info/91150332500M350.htm?pn=911-503-325-00-M350&bt=Y&fs=0&SVSVSI=911M
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Insert Tag Line HERE.....
This is a known problem in the Porsche parts catalog. The front piece has been incorrectly superceeded to the incorrect part number..
Marc |
The upper and lower are different, but left and right are the same ( just flip them over).
Lower is shorter and has shallower curve. Should be there somewhere. |
Front welding in catalog
Mark are you saying that the part in the catalog IS the lower, which is what im looking for, but the part number is incorrect? It does say upper on all those parts. Thanks
each side is the same...but
I understand each side are interchangeable but I am missing the lower on the left side. and need to buy one...Obviously if i move the right to left I will be missing the right side! Thanks
911 503 326 is the upper. 911 503 325 is the lower. The link in dg567's post #11 is what you need.
_______________ John 1988 Carrera Targa 3.2 G50 - Sold. 2017 Chevy Silverado K1500. |
Btw, as stated above the link in post #11 is definitely the right one. |
That’s great thanks all!!
