68 911 clunk in front end ?
Everything has been gone thru and brand new with good quality parts as part of its rebuild.
Intially for 2000 miles quiet.
Now I reverse out if my drive . Steer right to drive off and clunk. It's loud and harsh and does not seem to come thru the wheel.
I'm now at times getting it on the road on a hard right turn at very low speeds.
Not left turns and I can't replicate it while stationery in the garage.
I've gone thru and tightened it all but to no avail.
Any expert's want to hazard a guess.
Lyndon
Old 01-19-2021, 08:24 PM
Shock bushing? Or a dodgy lower ball joint?
Merv
Porsche 2003 996 Turbo
Porsche 1988 911 Carrera
Old 01-19-2021, 11:13 PM
Shock bushing as in the top ?
Lyndon
Old 01-19-2021, 11:21 PM
Depends on the type of shock but some (e.g., Koni) have a bump stop or plastic bushing that can rattle or clunk if not installed correctly. More likely however, if it is on turning and not felt through the steering, is the lower ball joint. Was that replaced and are all the nuts tight? Also if the torsion bar has not been installed correctly, height adjusted, and the front control arm not indexed properly there could be a clunk.
Merv
Old 01-19-2021, 11:38 PM
New genuine ball joints.
All torsion bars and indexing done properly.
Like I say it's a new thing and the front end is about 2000 miles old. Guess I'm going to pull it out and have a look. Only turning right it happens. ?
Lyndon
Old 01-20-2021, 01:33 AM
Flojo's Avatar
Bilstein upside down strut?
forgot to install the lower roll pin?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-20-2021, 02:42 AM
So nothing in the steering feel. Not a tie rod end bushing? Lug nuts tight? I like the roll pin thought. Was it tightened fully?
Merv
Old 01-20-2021, 03:06 AM
Roll pin ???
Old 01-20-2021, 03:07 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Press fit in bottom of Bilstein shocks, holds shock shaft in place..
Gary R.
Old 01-20-2021, 03:15 AM
My struts are Koni. Don't have them
Old 01-20-2021, 03:24 AM
Flojo's Avatar
loose sway bar mount then?
as you say "everything is new" it's difficult to narrow down where an install mistake is, could be anything...
Old 01-20-2021, 04:00 AM
check your lug nuts....
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-20-2021, 11:19 AM
Lug nuts are torqued to 96 ft lbs.
Car had no sway bars.
I will hoist it again next week for another look.
Lyndon
Old 01-20-2021, 12:33 PM
derek murray's Avatar
Double check the two M12 bolts at the rear of the skidplate. They run up through the torsion bar’s bushing carrier securing it to the car... if not installed really tight that clunk sound can happen.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 01-20-2021, 05:56 PM
Grappler
Rodsrsr's Avatar
Suspension pan rusted where front torsion bar connects? You did say its a 68 so it not unlikely.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-20-2021, 06:10 PM
Something with the control arms? Are there quality rubber bushings in there (there are one front and one at the rear of each control arm? Was the car height adjusted after they were fitted? Are torsion bar end caps fitted correctly and is the TB slotted fully into the front mount?
Merv
Old 01-24-2021, 12:13 AM
Zero rust. All best quality parts.
When I get it apart and or fixed will advise.
Lyndon
Old 01-24-2021, 12:15 AM
