3.6 conversion heating w/stock heat exch.
I would like to know what type of hose the 3.6 gurus used on their conversions. I am keeping the 993 heat exchangers, so i need a hose which connects the outlet of the exchangers (oval) to the connector for the heating.
Winter is coming and I would like to be ready!!! Thanks
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 Last edited by mmasse; 11-17-2005 at 01:43 PM.. |
On the top or the bottom?
On the bottom, I fabbed up my own connector with exaust tubing and a piece of aluminum dryer hose. For the top, there's a really trick carbon fiber piece available
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
thanks Tom. My problem is on the bottom, I already have the carbon fiber tube for the top
![]() Do you have any pics of your setup?
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
It isn't pretty, but it works...
A much nicer solution is to use the 993 cast aluminum heat crossover tube. I found one on this BBS for $75 I then used 2 1/2" aircraft defroster hose (the orange silicone high temp stuff ) which is the same as Porsche uses originally I think I paid less than $40 for 6 feet.I made 2 simple funnel adapters from sheetmetal to connect to the oval outlets. It works well and looks fine.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 11-17-2005 at 03:03 PM.. |
W/ 993 header use the 993 heat tube
You can see it here below the sheetmetal, if the cat was present it would be below the heat tube. On my 993 I use B&B headers w/ a 964 heat tube.
john, where can I get the 2 1/2" aircraft defroster hose ?
I called a small airplane repair place at our local airport,from the phone book.. They had it in stock for a Cessna I think I just described it as high temp silicone hose possibly orange and they had several diameters.Sold by the foot..A hydraulic hose supplier I spoke to knew exactly what I was looking for also but had to order it and I would have to take 12 ft @$8/ft.min. They suggested the aircraft industry used it for defroster or heater duct.
Timmons will sell you the same stuff I think he wanted $75-80 for 5 feet plus shipping.He wanted about $100 for the 2 sheetmetal adapter funnels.The end result looks exactly like a pic on his website but costs much less.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 11-17-2005 at 06:06 PM.. |
Take a look here at the very effective heating system I have with mostly stock 993 parts. I have a 993 heat tube for sale if you need one
![]() I got crabs this weekend! Chris
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Senior Member
Chris,
Just left you a msg on the other thread. Might be interested in the tube. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
What is the part number for the "cast aluminum heat crossover tube? Do you happen to know? |
I still have one of these 993 cast crossover tubes for sale
Heat exchanger inlet modified for valve cover access: ![]() 45º silicone elbow adapter connects engine air shroud hose to HE inlet (There's a short internal tube behind the double hose clamps to connect the SCEET hose to the silicone adapter. ![]() Heat exchanger Al outlet hose adapter (Revotec.com). I don't recall the large OD end (before reshaping), but the small end is 2.5" OD: ![]() ![]() Al adapter annealed, then ovalized and expanded a bit to fit heat exchanger outlet: ![]() Hose connection, HE to cabin hot air valves using add'l 2.5" (63mm) SCEET hose as above: ![]() ![]() Works for both Gillett and Bishoff HEs (Gillett shown). Add'l SCEET and hose connection tubes missing: ![]() Hope this helps, Sherwood |
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
