-   -   What Transmission Problem Could This Be? (http://forums.pelicanparts.com/porsche-911-technical-forum/1081669-what-transmission-problem-could.html)
mo-mon 12-24-2020 06:11 PM
Merry Christmas Pelicans!
While on a spirited run this morning, I was shifting from 2nd to 3rd at 6k rpm when I heard a bang & couldn't get into 3rd. I stopped. put the car in neutral, killed the engine.
Engaged 1st, started the car & was able to move. Shifted to 2nd, still ok but couldn't
get into 3rd. Drove it home in 2nd gear. When I stopped at the toll, clutch wasn't
working & the car lurched forward. Luckily, the barrier lifted & got home in 2nd.
I'm letting the car cool down before inspecting but what do you guys think is the
problem? Worn clutch? Shift fork? Car is a 1988 Carrera. TIA.
john walker's workshop 12-24-2020 06:24 PM
Some of them still have the original
rubber center clutch disc, which breaks up and blocks proper clutch disengagement.
mo-mon 12-24-2020 06:32 PM
Thank you John. Guess it's drop engine time.
G450X 12-24-2020 08:39 PM
Yup, they are still out there - I was driving my old SC through a neighborhood last year and saw a beautiful low mile (70k or so) Continental orange early SC with rear end jacked up inside a garage.
I stopped and talked to a nice gent, sure enough the original rubber centered clutch finally let go. That guy was raising cain how Porsche screwed up with their rubber centered clutches - after 40 years!
midnightrider36 12-27-2020 01:25 PM
if its an 1988 its a G50 car. did the G50's have rubber centered clutches as well?
HaroldMHedge 12-27-2020 01:53 PM
950.116.012.04
Here's one I recently pulled from my 87. I think it's the second clutch for my car since it had the updated clutch arm bushings.
http://forums.pelicanparts.com/uploa...1609105455.jpg
The part has been replaced with a spring center disc 950-116-012-54.
mo-mon 12-27-2020 06:37 PM
Hi Harold. Did you do replace clutch yourself? I'm thinking of tackling this myself although I've never done this before.
HaroldMHedge 12-28-2020 08:20 AM
mo-mon,
Yes, I'm doing the work myself on the clutch replacement but have not gotten it reinstalled since I'm working through a split case rebuild first.
The Bentley manual does a good job of explaining the engine/transaxle drop, separation and clutch replacement.
During the removal I bent the crossmember M12 bolt mounts. This is a common problem since the bolt and crossmember corrode together.
If you don't have a lift, it's difficult getting the car raised high enough to remove the engine/transaxle.
mo-mon 12-28-2020 05:11 PM
I do have the Bentley & the G50 pdf (Thanks KTL) but no lift. Hopefully the smaller RUF tribute rear bumpers that I have allow a lower height for removal.
HaroldMHedge 12-28-2020 05:44 PM
It takes awhile but you can build platforms (ex. 2×6) for both the jack and stands. Just go slowly and think safety.
