Harpo's Avatar
Trial-and-error 930 brakes installation
This has been an exercise in patience. I had to wait 3 weeks for USPS to deliver these 930 calipers. Yes this is the wrong caliper and that's why I mounted it upside-down. The correct caliper is still being cleaned in the ultrasonic tank. I didn't use the 930 caliper spacers ( 930.351.581.01) as others have done. Instead I used 4.4mm thick washer from the hardware store (way cheaper). Also with the 951 rims I didn't have to add spacers between the hub and the wheel. This also means that the rims I just got back from powder coating can't be used. These are the newer caliper design with out the banjo fitting. Not sure if I will have to back date the calipers
Old 12-24-2020, 07:10 AM
Harpo's Avatar
I attempted to create my own hat and rotor but ended up buying this assembly from Steve Weiner from Rennsport who was very helpful
Old 12-24-2020, 07:24 AM
stevie 77 930's Avatar
This has been an exercise in patience. I had to wait 3 weeks for USPS to deliver these 930 calipers. Yes this is the wrong caliper and that's why I mounted it upside-down. The correct caliper is still being cleaned in the ultrasonic tank. I didn't use the 930 caliper spacers ( 930.351.581.01) as others have done. Instead I used 4.4mm thick washer from the hardware store (way cheaper). Also with the 951 rims I didn't have to add spacers between the hub and the wheel. This also means that the rims I just got back from powder coating can't be used. These are the newer caliper design with out the banjo fitting. Not sure I I have to back date the calipers
Dave, you're good on the fronts. The factory brake-lines for the front caliper to the flex hose is all you need on the fronts. The rears area different story....
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-24-2020, 08:05 AM
Harpo's Avatar
Thanks Stevie,
I do have the the 930 hard lines to run from the calipers to the flex line.
Old 12-24-2020, 08:34 AM
Harpo's Avatar
I have already trimmed of the ears from my trailing arms and fortunately the calipers had already been modified to fit SC arms
Old 12-24-2020, 08:38 AM
Harpo's Avatar
Because my rear calipers didn't come with the required spacers I made these. They are 8mm thick.
Old 12-24-2020, 08:48 AM
Irrationally exuberant
ChrisBennet's Avatar
I've heard someone called this "Van Gogh-ing the trailing arms"
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-25-2020, 01:42 PM
