-   -   Knocking under acceleration, help (http://forums.pelicanparts.com/porsche-911-technical-forum/108196-knocking-under-acceleration-help.html)
jason2guy 04-27-2003 10:28 AM
when hot and under pretty hard acceleration my car will knock.
valve knock. timing is set to stock.
what should i try???
bell 04-27-2003 11:36 AM
what octane fuel are you using?
Vipergrün 04-27-2003 12:08 PM
Have you checked your head studs lately? Have you checked for exhaust leaks? Inspected your timing chain/tensioners lately? If your timing is set to 5 degrees BTDC, I do not see how it could be detonation. Many of us run at 35 degrees BTDC max advance at 6K RPMS, which is approx 10-12 degrees at idle. with no detonation issues...
jason2guy 04-27-2003 01:56 PM
im using super. just did a major service, no headstuds broken.
checked timing. im gonna double check the timing and advance function to be sure. thanks
rstoll 04-27-2003 03:19 PM
Could be carbon buildup. Try a bottle of Techron.
jason2guy 04-27-2003 03:22 PM
thats a good idea, ill try that
rstoll 04-27-2003 03:25 PM
It did the trick for me. I bought my 83 about 2.5 yrs ago. It did the very same thing. Hot, under hard accleration, knocked. I ran a couple bottles of Techron and no more knock. Also treat it to a bottle of Marvel Mystery Oil in the tank every now and then.
Jdub 04-27-2003 03:31 PM
Did you move to a synthetic oil recently?
John
jason2guy 04-27-2003 03:42 PM
nope. i use castrol 20/50.
Vipergrün 04-27-2003 04:18 PM
Make sure you have Castrol on hand....you'll need to do an oil change after running the Techron thru :)
tops911 04-27-2003 04:18 PM
One thing to check is total advance. On my '78 SC it would ping on accleration, the timing was good at idle. However I got something like 45 degrees advance at 4500 rpm. After taking out the distributor I found one of the advance springs had come off. After putting the spring back on (and a good cleaning) my pinging stoped.
