Knocking under acceleration, help
when hot and under pretty hard acceleration my car will knock.
valve knock. timing is set to stock.
what should i try???
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-27-2003, 10:28 AM
one of gods prototypes
bell's Avatar
what octane fuel are you using?
Brought to you by Carl's Jr.
Old 04-27-2003, 11:36 AM
Formerly bb80sc
Vipergrün's Avatar
Have you checked your head studs lately? Have you checked for exhaust leaks? Inspected your timing chain/tensioners lately? If your timing is set to 5 degrees BTDC, I do not see how it could be detonation. Many of us run at 35 degrees BTDC max advance at 6K RPMS, which is approx 10-12 degrees at idle. with no detonation issues...
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-27-2003, 12:08 PM
im using super. just did a major service, no headstuds broken.
checked timing. im gonna double check the timing and advance function to be sure. thanks
Jason
81 SC
97 328is
Old 04-27-2003, 01:56 PM
rstoll's Avatar
Could be carbon buildup. Try a bottle of Techron.
Robert Stoll
83 911 SC
83 944
Old 04-27-2003, 03:19 PM
thats a good idea, ill try that
Jason
81 SC
97 328is
Old 04-27-2003, 03:22 PM
rstoll's Avatar
It did the trick for me. I bought my 83 about 2.5 yrs ago. It did the very same thing. Hot, under hard accleration, knocked. I ran a couple bottles of Techron and no more knock. Also treat it to a bottle of Marvel Mystery Oil in the tank every now and then.
Robert Stoll
83 911 SC
83 944
Old 04-27-2003, 03:25 PM
Senior Member
Jdub's Avatar
Did you move to a synthetic oil recently?
John
'78 Targa in Minerva Blue
Old 04-27-2003, 03:31 PM
nope. i use castrol 20/50.
Jason
81 SC
97 328is
Old 04-27-2003, 03:42 PM
Formerly bb80sc
Vipergrün's Avatar
Make sure you have Castrol on hand....you'll need to do an oil change after running the Techron thru
Cheers
-Brad
2015 Cayman GTS
Old 04-27-2003, 04:18 PM
tops911's Avatar
One thing to check is total advance. On my '78 SC it would ping on accleration, the timing was good at idle. However I got something like 45 degrees advance at 4500 rpm. After taking out the distributor I found one of the advance springs had come off. After putting the spring back on (and a good cleaning) my pinging stoped.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
